top end oiling restrictions on a BB #1849247
06/15/15 12:25 AM
06/15/15 12:25 AM
Australia
P
Project kickin A Offline OP
P
Australia
Ok so here is how I read it
when using a solid cam or solid roller and Harland Sharp rockers we want to restrict or control the amount of oil going to the heads.
One way of doing this is to groove No4 cam journal for full time oiling then drill and tap the oil passage in the head and screw in a .070 holley main jet into it?
correct?
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1849377
06/15/15 04:01 AM
06/15/15 04:01 AM
correct?
That is one way, I have bought and am using some of the World blocks, they oil the rocker full time by the rocker arm oiling passage fed directly from the right side lifter oil galley,not through the cam tsk They have a .040 restrictor in them stock work I have used .039 restrictors successfully on several stock blocks with full time oiling to the rockers like your suggesting on Harlnad Sharp rockers, same size(.039) on several other motors with Indy heads with external full time oiling with H.S. rockers also up On a extruded aluminum or any non needle bearing rockers I may end up using a bigger restrictor(.080) to start with and then decde to change it up or down on the size dependent on the results scope IHTHs up
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1849383
06/15/15 05:04 AM
06/15/15 05:04 AM
Australia
P
P
Australia
.039? that's pretty small
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1849395
06/15/15 06:29 AM
06/15/15 06:29 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
wouldn't a hose with smaller inside diameter work too on indy heads
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1849397
06/15/15 07:19 AM
06/15/15 07:19 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am afraid to use a smaller jet[.100] edl vic heads but I use a Mig tip in the rocker stand.I do not want to confuse a oil drain issue with too much oil.Good luck with what you decide.
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1849568
06/15/15 01:27 PM
06/15/15 01:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What heads?
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1849756
06/15/15 05:41 PM
06/15/15 05:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I drill a set set screw - then you don't have to drill out the oil passage so big for a jet. I'm using a .062 hole for Harland Sharp rockers.
Re: top end oiling restrictions on a BB [Re: Clanton] #1849758
06/15/15 05:50 PM
06/15/15 05:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should try the Holley fuel jets... they come in all sizes
wave
Re: top end oiling restrictions on a BB [Re: MR_P_BODY] #1850041
06/15/15 10:41 PM
06/15/15 10:41 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Muscle Motors did a world block for me and I wish they had read Andy Finkbeiners book cause it says in there to bush lifter bores to control over oiling the top end. They relized this on the dyno when it filled vacuum pump puke tank, or maybe when it sucked the pan dry. Their bandaid was to use pushrods with restrictors. This will make lifters hemmorage oil every time lash is taken up and increase windage and cause low oil psi, 15-20 psi at 1200rpm at 150 degrees. I guess since this was their first World block build it was just a learning curve.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: top end oiling restrictions on a BB [Re: Project kickin A] #1850307
06/16/15 10:06 AM
06/16/15 10:06 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
When using an oil restrictor should you always prime the shaft before startup to prevent a dry system problem? Or lube the PR,valve tips and run it?Thanks Mr.P I was too lazy to use a pin drill of .070 and used a .100.I will look at the Holley jets closer to use.I will check if the holley jet will fit in the rocker stand.[1/4" hole]
ps: The holley jet is .310 so it can be made to fit a 1/4".
