Shifting problems on my 1969 340 4 speed dart #1849781
06/15/15 06:45 PM
06/15/15 06:45 PM
British Columbia, Canada
3
340Forrest Offline OP
Okay so I just finished the restoration on my dart and I've been have problems with shifting. I can't down shift without it grinding, can't put it into second with it popping out or grinding and if I shift to fast it grinds when I put it into gear. The z bar is also rubbing on the starter, I'm in need of help. Everything is stock on the car. Here a pic of all the pieces for the clutch linkage
Re: Shifting problems on my 1969 340 4 speed dart [Re: 340Forrest] #1849783
06/15/15 06:48 PM
06/15/15 06:48 PM
3
Another view of z bar
Re: Shifting problems on my 1969 340 4 speed dart [Re: 340Forrest] #1849867
06/15/15 08:08 PM
06/15/15 08:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You need to remove the bellhousing dust cover and check the clutch disc air gap with the pedal fully depressed.
Re: Shifting problems on my 1969 340 4 speed dart [Re: 340Forrest] #1850113
06/15/15 11:58 PM
06/15/15 11:58 PM
Good Ole USA
djw383 Offline
djw383  Offline
Good Ole USA
I had a similar issue and it ended up being the shifter box itself being worn out. You have a series of trial and error issues.
Re: Shifting problems on my 1969 340 4 speed dart [Re: djw383] #1850130
06/16/15 12:21 AM
06/16/15 12:21 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If it grinds, you either have bad syncros or the clutch needs more air gap. I'd adjust the air gap first, as it don't cost anything. Another possibility is that the pilot bushing is too tight......
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Shifting problems on my 1969 340 4 speed dart [Re: 68LAR] #1850250
06/16/15 05:21 AM
06/16/15 05:21 AM
what part is wrong/misadjusted that the zbar is rubbing? that'd be the first thing I'd resolve (then air gap) & I'd think the zbar prob would be skewing the air gap
Re: Shifting problems on my 1969 340 4 speed dart [Re: 340Forrest] #1850479
06/16/15 02:22 PM
06/16/15 02:22 PM
pa.
dan9 Offline
dan9  Offline
pa.
If you are using a McCleod pressure plate it could cause some of those problems. It seems they had a design flaw. I bought mine in a conversion kit, they sent me a newer design and all is well.
