hood emblem for 71 charger??
#1829113
05/18/15 01:02 PM
05/18/15 01:02 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Car bout done with paint. Has buldge hood. Will a 440. I have a extra 6 pack setup all new for it. Does a 6 pack car have differnt emblem ? Or just 440 magnum? Are they the same emblem as on a challenger? I see new ones for challenger but not a 71 charger
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: hood emblem for 71 charger??
[Re: toplescuda]
#1829719
05/18/15 11:58 PM
05/18/15 11:58 PM
Posts: 32 Tennessee
moparjunkyard
Tennessee
Here is a picture of an NOS set for 440 Six Pack Chargers and Super Bees They are different.
1968 A-STOCK AUTOMATIC/426 Hemi Super Bee Numbers Matching
[Re: moparjunkyard]
#1829725
05/19/15 12:01 AM
05/19/15 12:01 AM
Posts: 32 Tennessee
moparjunkyard
Tennessee
Actually, I believe it is the same part number as Challenger Emblem.
[Re: toplescuda]
#1829885
05/19/15 10:08 AM
05/19/15 10:08 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
A 71 charger (r/t?) And a 71 super bee. Has 2 differnt emblems? Does the emblems have the post on back or are that stick on? If post. Would they fit the same holes thats in a 74 buldge hood? (For charger)
[Re: toplescuda]
#1830616
05/20/15 09:11 AM
05/20/15 09:11 AM
Posts: 32 Tennessee
moparjunkyard
Tennessee
I have had both 71 R/T's and 71 Super Bee's. Normally the Super Bee Came Standard with 383 with an indented hood with 383 Magnum Emblem. You could bump up to a 440 Six Pack or Hemi and each one would have a different emblem. There were also 26 71 Super Bees Made with a 440 magnum and I used to have one. They all had tips on the emblems and the hood had holes punched in it as far as I know. The 71 Charger of course was standard with a 440 and usually had the Hood with the louvers in it or the air grabber hood. Optional would also be 426 Hemi or 440 Six Pack. In 74 The six pack was no longer available nor the Super Bee Package.They did make around 200 440 Rallye cars and I believe the emblem was the same, but just a bulge hood with no indentations, louvers or air grabber. Most Chargers in 74 had the 318 or 400 with flat hood. Hope this helps.
Richard
[Re: toplescuda]
#1831038
05/20/15 08:04 PM
05/20/15 08:04 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
You dont know if a 440 six pack emblem would fit the factory holes on my 74 ralley buldge hood Possible to get a measurement on the pins on back of the 440 six pack emblem I can check the distance apart of the holes in my hood?
[Re: toplescuda]
#1836466
05/29/15 05:08 AM
05/29/15 05:08 AM
Posts: 5,275 near Harrisburg, Pa
440trk
near Harrisburg, Pa
Hmmm... a 74 bulge hood shouldn't have holes for emblems....they went to stick on emblems in 73. That being said...the 71-2 emblems all have the same pin layout, so you should be OK. I can get measurements for ya. I currently have 340 MAGNUM,440 MAGNUM and 440 Sixpack emblems. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) edited: Added info below A 71 charger (r/t?) And a 71 super bee. Has 2 differnt emblems?
The reason the Superbee and the R/T are different, is that the Superbees had the emblems mounted in the hood insert, not on the outer buldge of the hood as the R/T hoods do. Now a Superbee with the Ramcharger Hood.....used the same emblems as the R/T.
[Re: toplescuda]
#1837944
05/31/15 01:17 PM
05/31/15 01:17 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
That would be very helpfull. The hood is a 74 buldge hood (no vents on rear of it) hood was a very nice un repainted hood. No chips around the hole. Leaves me to belive that was there sence new..
[Re: toplescuda]
#1837948
05/31/15 01:25 PM
05/31/15 01:25 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Only pic I have. Wich dont really matter cause hood is painted now
[Re: toplescuda]
#1837953
05/31/15 01:30 PM
05/31/15 01:30 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Back side. Cant tell but wasnt all pitted up
[Re: toplescuda]
#1837957
05/31/15 01:34 PM
05/31/15 01:34 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Found a pic before started on the hood
[Re: toplescuda]
#1848142
06/13/15 03:38 PM
06/13/15 03:38 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
So can someone tell me for certain. Before I buy some new 440 six pack emblems for a challenger. Will these fit my hood?
[Re: toplescuda]
#1849107
06/14/15 10:21 PM
06/14/15 10:21 PM
440trk
near Harrisburg, Pa
The pin spacing on all Charger hood emblems are the same. I think the Challenger emblem looks different...but uses the same pin spacing, so it should fit
For the record, I compared the pin layout for the following 71 charger emblems:
340 Magnum 440 Magnum 426 HEMI 440 Sixpack
[Re: 440trk]
#1849414
06/15/15 09:46 AM
06/15/15 09:46 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Sweet thank you sir. Thats a lot of help I should get car back Thursday. iF. nothing goes wrong
[Re: 440trk]
#1849566
06/15/15 01:26 PM
06/15/15 01:26 PM
Posts: 87 Wisconsin
EccentricMagpies
Wisconsin
that certainly isn't true The '74 bulge hood had: 0 holes in the 318 and no emblems 2 holes for the 360 with "MAGNUM" emblem 3 holes for the 400/440 with "400 MAGNUM" or "440 MAGNUM" emblem The '74 hood simply never had vents.
Rallye 4spd WH23L4xxxxxx Rallye tx9 x 3 + V6X '69 Dart Swinger-340 4spd
[Re: toplescuda]
#1849582
06/15/15 01:48 PM
06/15/15 01:48 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Orignal paint 74 ralley hood
[Re: mopars4ever]
#1849724
06/15/15 04:43 PM
06/15/15 04:43 PM
Posts: 87 Wisconsin
EccentricMagpies
Wisconsin
My 73 340 charger with a buldge hood had holes for emblem pins. Right. A difference between '73 and '74. 340 went to a 360 and the emblem changed. Also, '73 had vents in the rear.
