I need some help figuring out what I disconnected or failed to reconnect.
The story: I had oil loss and the plenum pan gasket failed. Took the weekend and I replaced the gasket. Put it all together and let the silicon gasket cure for 24 hours as per the instructions.
Today, I topped off the fluids and started the truck up. It won't run. If I sit in it and keep some pressure applied to the gas pedal it will run. I get a check engine light and as soon as I let off the gas it stalls. It is a quick stall, no sputtering or stuttering just a quick die.
I had a friend get in it and had them run the truck while I listened to it, I could not hear anything abnormal.
I can't find anything that is not connected.
Any hints or things I should look at would be greatly appreciated.
1999 Dodge Ram 1500 with a 5.2 liter Magnum.
