Re: Help Calibrating Fuel Sending Unit A-body Rallye Dash
[Re: FJR doc]
#1849412
06/15/15 09:39 AM
06/15/15 09:39 AM
RapidRobert
12V input to VL. ~5V out from VL to one gauge terminal. other gauge terminal goes out/rearward to tank sending unit. sending unit is grounded. float rises=less resistance=more current flowing & gauge up front moves over toward F. Not being patronizing just a BTT for ya
[Re: FJR doc]
#1850234
06/16/15 04:04 AM
06/16/15 04:04 AM
RapidRobert
I ain't never seen any aftermarket product that has even come close to the high percentage of out of the box inaccurate reading units like sending units. If I had my druthers I'd want it to read E when I have five miles left in the tank. I got around this by keeping my functioning 5/16 sender & soldering in a bung in my new Frankie Mitchell (God rest his soul) spectra gas tank (from Canada iirc)
[Re: FJR doc]
#1850592
06/16/15 05:51 PM
06/16/15 05:51 PM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
I was able to test my original sending unit and a repro that was supposedly manufactured by the original supplier. The original sender needed only minor tweeking to set endpoints. The repro unit did not register in a linear fashion therefore I won't be using it. I guess it's just another poorly manufactured waste of money. I had same issue trying to read unit with an Ohm meter. Installed and it only goes to 3/4 when tank is full. Spends a lot of time around the 1/4 tank mark on gauge. I also built an electronic limiter, puts out constant 4.9 volts. How were you "tweaking" the sending unit? This is a made by orig mfg, not the Chinese version. My original was junk
[Re: RapidRobert]
#1850596
06/16/15 05:56 PM
06/16/15 05:56 PM
Bull1tt
Pgh, PA
I ain't never seen any aftermarket product that has even come close to the high percentage of out of the box inaccurate reading units like sending units. If I had my druthers I'd want it to read E when I have five miles left in the tank. I got around this by keeping my functioning 5/16 sender & soldering in a bung in my new Frankie Mitchell (God rest his soul) spectra gas tank (from Canada iirc) I agree, these are terrible!
