2005 Dodge Magnum wagon 3.5 timing belt
#1848009
06/13/15 12:20 PM
06/13/15 12:20 PM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
at what point am I walking on thin ice ..
I have 101,000 on it
I know it needs replacing, are we at warp nine ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 2005 Dodge Magnum wagon 3.5 timing belt
[Re: bigdad]
#1848232
06/13/15 06:57 PM
06/13/15 06:57 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
Its a SOHC (with wierd rockers) and the tensioner is just a spring tensioner not an oil pressure operated one. Both of those to me make it not so much a time bomb. Also has no balance shafts or anything as well. That being said you should still obviously do it soon, but yeah.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: bigdad]
#1848605
06/14/15 12:02 PM
06/14/15 12:02 PM
Posts: 905 SD
zrxkawboy
SD
On the older ones (90s), I'm pretty sure the recommendation was 105k miles. Not sure if that applies to yours.
It's Swifty! Swifty, you toad sucker!
