E Body under hood insulation. #1848717
06/14/15 01:50 PM
06/14/15 01:50 PM
Ohio
V
viperakron Offline OP
V
Ohio
Who makes the best pad that will pass for original? Needs a hole in it, right? Are these the correct clips?
Re: E Body under hood insulation. [Re: viperakron] #1848796
06/14/15 03:10 PM
06/14/15 03:10 PM
classic industries might
Re: E Body under hood insulation. [Re: viperakron] #1849560
06/15/15 01:22 PM
06/15/15 01:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What year? Metal clips were used in 70 and 71 I think. My 73 uses plastic clips. Most agree that a molded under hood pad was used. My 73 and a few others I've seen came with a generic die cut pad. My guess is most if not all of the dealers are selling the same pads. It probably doesn't matter who you buy it from. Pick the company that gives you the best service.
