Re: 71 b body set ups give me some pointers.
[Re: MuuMuu101]
#1847358
06/12/15 01:58 PM
06/12/15 01:58 PM
Posts: 13,878 Willow Grove PA
71sat440
Willow Grove PA
I'm not too familiar with B Bodies... But you say you like the nostalgic muscle car look. What size wheels do you plan on running on your Satellite? I know for a fact I could not fit 17" wheels with the Brembo-style brakes on my Dart.
Torsion bars shouldn't be an issue for looks as you can adjust the ride height to your choosing. I'm sure there are plenty of other options for leaf springs to give you better handling and a similar ride height.
Hotchkis isn't your only option for sway bars. I'd also look into Hellwig or Firmfeel. Some kits may offer the mounting brackets and I think Hotchkis might sell them.
For steering, your better upgrade is the Borgeson power steering box; however it's pretty expensive and some people have had difficulties with instillation.
I'd also invest in a good pair of shocks. Minimum, Bilstein's from PST (I believe they sell them) or get Hotchkis's non-adjustable ones. I was going to use 17 inch mustang rims I had sitting around. I was gona go with the brembo style because I have the cobra brakes (on a mustang) and while they are nice I kinda wanted an upgrade. Do they have wheel rates listed for springs and if so how should a front wheel rate compare to a back one?
[Re: 71sat440]
#1847587
06/12/15 07:40 PM
06/12/15 07:40 PM
Posts: 16,149 Mesa, Arizona
dart4forte
Mesa, Arizona
I'd also invest in a good pair of shocks. Minimum, Bilstein's from PST (I believe they sell them) or get Hotchkis's non-adjustable ones. I was going to use 17 inch mustang rims I had sitting around. I was gona go with the brembo style because I have the cobra brakes (on a mustang) and while they are nice I kinda wanted an upgrade. Do they have wheel rates listed for springs and if so how should a front wheel rate compare to a back one? I'm running the complete Firm Feel suspension on my 71RR airgrabber car. I considered a brake upgrade along with 17" wheels and tires. Dick at Firm Feel told me it wouldn't be a problem.
Abe Lincoln
[Re: 71sat440]
#1848115
06/13/15 03:08 PM
06/13/15 03:08 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
What are your suggestions.
If'n I was you... I'd do some research...
[Re: 71sat440]
#1848243
06/13/15 07:30 PM
06/13/15 07:30 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
[quote=71sat440]
Right now I'm set towards the doctor diff brembo style front and cobra style rear brakes.
I had dr diff old 13" kit and I had to go to 18" rims
Will these eliminate any type of sway bar choices.
No
Sway bars, my lower control arms have no mounting brackets, does anyone sell the brackets so i can weld them on or am I just better off finding a set with them and rebuilding them?
I believe firm feel and hotchkis sell these
Or do they have aftermarket set ups that bolt on different?
Same
Wheel rates how hard is it going to be to match a good set between the front torsion bars and rear springs?
Companies like firm feel and hotchkis and xv ect. Have done this testing already so u dont have to.
Steering, not real fond of the factory box and would like something a bit more responsive.
Firm feel stage 3. The boregson is a hit or miss right now and a expensive one at that.
Also pick up andys book mopar bbody performance upgrade 1962-79 [\quote]
[Re: AndyF]
#1848600
06/14/15 11:52 AM
06/14/15 11:52 AM
dart4forte
Mesa, Arizona
You are asking a lot of very basic questions so you might want to start off with the book I wrote on B-body performance upgrades. You can get it at Amazon. It will answer most of the basic questions and it has photos of parts and contact info for vendors. Which book is that?
Abe Lincoln
[Re: 71sat440]
#1848659
06/14/15 01:09 PM
06/14/15 01:09 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Those Mustang wheels aren't going to work. That's what I used for my mock-up wheel and they were rubbing the calipers.
[Re: dart4forte]
#1848808
06/14/15 03:24 PM
06/14/15 03:24 PM
71sat440
Willow Grove PA
You are asking a lot of very basic questions so you might want to start off with the book I wrote on B-body performance upgrades. You can get it at Amazon. It will answer most of the basic questions and it has photos of parts and contact info for vendors. Which book is that? I beleive he's talking about this one. http://smile.amazon.com/B-Body-Performan...y+f+b+body+book
[Re: MuuMuu101]
#1848819
06/14/15 03:34 PM
06/14/15 03:34 PM
71sat440
Willow Grove PA
Those Mustang wheels aren't going to work. That's what I used for my mock-up wheel and they were rubbing the calipers. Thanks for the heads up, might go with just the cobra upgrade after all. I'm familiar with the system, parts availability is wide. Might just keep it simple with a firm feel 3 box, re informed k member. 1.12 t bars and springs with blisters and doctor diff cobra brakes front and back and some frame connectors. Who has some good connectors? I see the ones that follow the floor pans on both UScartool and XV but I remember some drama for both on moparts. Also does anyone know if firm feel brings stuff to carlisle so you can save on shipping and core charges?
[Re: 71sat440]
#1848854
06/14/15 04:33 PM
06/14/15 04:33 PM
Posts: 921 Long Island, NY
shocktrp
Long Island, NY
You are asking a lot of very basic questions so you might want to start off with the book I wrote on B-body performance upgrades. You can get it at Amazon. It will answer most of the basic questions and it has photos of parts and contact info for vendors. Which book is that? I beleive he's talking about this one. http://smile.amazon.com/B-Body-Performan...y+f+b+body+book That's one of the books I have. It's a good read.
[Re: 71sat440]
#1849154
06/14/15 10:56 PM
06/14/15 10:56 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I haven't seen Firm Feel in years at Carlisle. It would be a long round trip for them. i also understand Mancini has dropped out of attending, which I don't understand, but if they have enough money, great.
[Re: Dan@Hotchkis]
#1849264
06/15/15 12:37 AM
06/15/15 12:37 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Just as an FYI, we've been running some pretty good show specials this year. 25% off list price/no tax/free shipping if you buy at the show and we'll be at Carlisle... Just saying... This^^^^^, great business technique, get out and meet people,show your junk, sell it and help cover the costs of playing all at the same time. Good stuff!
Mopar to the bone!!!
