Changing fuel sending unit
#1846723
06/11/15 05:15 PM
06/11/15 05:15 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Do you need to drop the tank completely, to change out the fuel sending unit on a 72 roadrunner?
1969 Dodge Dart Swinger
Re: Changing fuel sending unit
[Re: MikeyT]
#1847090
06/12/15 12:34 AM
06/12/15 12:34 AM
RapidRobert
Do you need to drop the tank completely, to change out the fuel sending unit on a 72 roadrunner? not if it goes in the side like on an A body tank. EDIT meant to say on FRONT side (like A bodies).
[Re: MikeyT]
#1847102
06/12/15 12:46 AM
06/12/15 12:46 AM
MikeyT
Watertown, WI
It actually does, goes right above the rear passenger wheel
