Backward gas gauge reading
#1845726
06/10/15 01:48 PM
06/10/15 01:48 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I have seen a LOT if issues resolve with posts here but NEVER this one! When we finished the build my first stop was the gas station to fill up. The gauge read 1/4 at the shop and I was thinking that was about right based on the amount we put in via cans. The gauge went from 1/4 to empty after filling up and as I drive it is climbing toward full!!!!! WTF??????????
Driving modern convenience in classic beauty
Re: Backward gas gauge reading
[Re: Darius]
#1845736
06/10/15 02:00 PM
06/10/15 02:00 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
and as I drive it is climbing toward full!!!!! OPEC-proof car, congrats! But keep an eye out for the black suburbans following you to stop technology. For real though, that is a good one. What are you using for a sending unit and gauge? Was it all running through a body controller?
[Re: Darius]
#1845775
06/10/15 03:02 PM
06/10/15 03:02 PM
Posts: 3,070 N.W. Florida
Fat_Mike
N.W. Florida
I have no idea, but your question peaked my curiosity and I scoured around the net to see what I could find out about how the system operates. After reading this website ( http://auto.howstuffworks.com/fuel-gauge2.htm ) and using a multimeter, I'll bet you can figure out where it's going wrong.
[Re: Darius]
#1845778
06/10/15 03:03 PM
06/10/15 03:03 PM
Posts: 25,826 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Factory spec sender or aftermarket gauge sender.
[Re: Darius]
#1845783
06/10/15 03:10 PM
06/10/15 03:10 PM
Darius
Sacramento, Ca
Stock sending unit, Autometer gauges, we re-wired the entire car. The only grounding issue we had was some paint in the way of a turn signal light. The gauge seems to be moving in the opposite direction so something is getting through in the way of signal so I don't think it is a grounding issue. I will look at that site, thanks Mike
[Re: Darius]
#1846336
06/11/15 12:19 AM
06/11/15 12:19 AM
Posts: 120 North Seattle, Washington. USA
U code RR
-Ford and Mopar factory fuel gauges read lo ohms full, high ohms empty(70-10 if I remember correctly). GM is the opposite. I would guess your AutoMeter is for a GM application. You might try to switch the wires on the guage. I don't know if that will work or not.
When seconds count...
The Police are only minutes away.
Smith and Wesson are your friends.
[Re: Darius]
#1846404
06/11/15 02:03 AM
06/11/15 02:03 AM
Darius
Sacramento, Ca
Thanks for all the input guys. I will let you know once we get a minute. In the mean time, when I get to 7/8 full I will make sure there is a gas station nearby;-)
[Re: U code RR]
#1846408
06/11/15 02:26 AM
06/11/15 02:26 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
-Ford and Mopar factory fuel gauges read lo ohms full, high ohms empty(70-10 if I remember correctly). GM is the opposite. I would guess your AutoMeter is for a GM application. You might try to switch the wires on the guage. I don't know if that will work or not. Yes that why I say you need to know which type gauge it is. The Mopars used the bi-metal type gauges that use the 5 volt feed to them and they bend a bi-metal strip which moves the needle by how much current goes through the bi-metal gauge. The magnetic type like GM used works on 12 volts but uses a two winding gauge as one winding gets 12 volts in it to ground and it pulls the needle one way and the other winding has current through it and the sending unit to pull the needle the other way and how much the needle moves is by the balancing of which winding is pulling more. And I believe the sending unit for the magnetic type may work in reverse of the bi-metal gauges. Ron
[Re: 383man]
#1846429
06/11/15 03:54 AM
06/11/15 03:54 AM
RapidRobert
Thanks Ron, from the descrip I thought I was in the twilight zone for a bit till you said it (likely) is a general merchandise part that works totally different
