Re: 383 head gaskets............. [Re: 4BBodies] #184502
01/09/09 10:37 AM
01/09/09 10:37 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
Re: 383 head gaskets............. [Re: ngpSatellite] #184503
01/09/09 11:23 AM
01/09/09 11:23 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
I used the shim gaskets on my 383. Heads had a cleanup cut but block still has the factory cut on it. No sealer, put on dry. No leaks, even with a 150 shot. My pistons are .014 on the hole and, yes, the thin gaskets raised my compression from 8.8 to 9.2. I'm glad I bought a new set for the new bullet going together.
Re: 383 head gaskets............. [Re: farmington] #184504
01/09/09 12:21 PM
01/09/09 12:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
where is Zippy ??
why did mopar raise the price on those gaskets 150 bucks ??
I bought 5 sets from summit in the last 2 years and now I'm glad I did ...
Re: 383 head gaskets............. [Re: JohnRR] #184505
01/09/09 12:31 PM
01/09/09 12:31 PM
You should offer up 4 of those sets to us. there's no reason to be sitting on a stash that large . Zippy is lost. I want to say that he is deceased but the last time I did that people believed me.
Re: 383 head gaskets............. [Re: JohnRR] #184506
01/09/09 01:35 PM
01/09/09 01:35 PM
AndyF Offline
AndyF  Offline
The steel shim gaskets aren't available anymore so MP switched to the Cometic gaskets. That is why there is a big price increase. The vendor who was making the steel shims stopped making them.
I think I have a few sets of the steel shims stashed away somewhere. I haven't built a motor with iron heads in so long I've forgotten where the steel shim gaskets are.
Re: 383 head gaskets............. [Re: AndyF] #184507
01/09/09 01:47 PM
01/09/09 01:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The last set of steel shims I bought from in an MP HEMI teardown kit were made by felpro , I'll have to look who made the B/RB gasket ..
Otherwise just order the mr. gasket piece , the price is 20 bucks , they do have a larger bore though .
I might order a few sets of the mr. gaskets so I am sure I have enough
Re: 383 head gaskets............. [Re: JohnRR] #184508
01/09/09 03:24 PM
01/09/09 03:24 PM
I have one pair, I hope they do Ok. I'll for sure coat em with a couple of thin coats of copper coat.
Re: 383 head gaskets............. [Re: RapidRobert] #184509
01/09/09 11:50 PM
01/09/09 11:50 PM
napa has them listed.
Re: 383 head gaskets............. #184510
01/18/09 05:10 PM
01/18/09 05:10 PM
Mechanic Falls, Maine
4BBodies Offline OP
mopar addict
4BBodies  Offline OP
mopar addict
I ended up getting a pair of Mr. Gasket #1135's for about $35 from Parts America. Back ordered, but I only had to wait a week. I had my heads checked by a machinist friend, they are flat, as is the block. So I am going to get a can of Permatex copper spray gasket and use them.
Re: 383 head gaskets............. [Re: 4BBodies] #184511
01/18/09 05:27 PM
01/18/09 05:27 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Mopar makes some special sealer for the shim steel gaskets. It spray from a can and looks like thin syrup. I use it on all of my intakes as well. Good stuff and never had a leak.
Re: 383 head gaskets............. #184512
01/18/09 09:17 PM
01/18/09 09:17 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
They do, but its a copper gasket, Felpro 8519SP
From their web site: Problem Solver for Applications where the Head & or Block have Required Excessive Machining.; Dead Soft Copper Material
There isnt a fire ring on them..
They are .020 with a 4.547" bore.
Havent found any steel shim head gaskets from NAPA. I really want a set of my 383, and I get such a good price break from NAPA, its hard for me to shop anywhere else.
If anyone has a felpro number for a steel shim gasket...I'd appreciate it.
Whats the MR Gasket Number? NAPA carries MR Gasket parts.....
Re: 383 head gaskets............. [Re: 74fldart] #184513
01/18/09 09:33 PM
01/18/09 09:33 PM
Southern Indiana
75RoadRunner Offline
Southern Indiana
Mill your heads .030 and use the thick gaskets. You will be right at the stock compression rate, and won't have to worry about a leak.
Re: 383 head gaskets............. [Re: 75RoadRunner] #184514
01/18/09 11:50 PM
01/18/09 11:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
cost to do all the machining will be about the same as buying the 177 dollar mopar gasket .
