Re: 383 head gaskets.............
[Re: AndyF]
#184507
01/09/09 01:47 PM
01/09/09 01:47 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
The steel shim gaskets aren't available anymore so MP switched to the Cometic gaskets. That is why there is a big price increase. The vendor who was making the steel shims stopped making them.
I think I have a few sets of the steel shims stashed away somewhere. I haven't built a motor with iron heads in so long I've forgotten where the steel shim gaskets are.
The last set of steel shims I bought from in an MP HEMI teardown kit were made by felpro , I'll have to look who made the B/RB gasket ..
Otherwise just order the mr. gasket piece , the price is 20 bucks , they do have a larger bore though .
I might order a few sets of the mr. gaskets so I am sure I have enough
[Re: JohnRR]
#184508
01/09/09 03:24 PM
01/09/09 03:24 PM
RapidRobert
I have one pair, I hope they do Ok. I'll for sure coat em with a couple of thin coats of copper coat.
[Re: RapidRobert]
#184509
01/09/09 11:50 PM
01/09/09 11:50 PM
[Re: 75RoadRunner]
#184514
01/18/09 11:50 PM
01/18/09 11:50 PM
JohnRR
Mill your heads .030 and use the thick gaskets. You will be right at the stock compression rate, and won't have to worry about a leak.
cost to do all the machining will be about the same as buying the 177 dollar mopar gasket .
