How much HP to run low 10s
#1844398
06/08/15 07:09 PM
06/08/15 07:09 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
-65Valiant 2910Lb with a ironheaded smallblock. How much HP to run low 10s?
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: How much HP to run low 10s
[Re: fed]
#1844439
06/08/15 08:10 PM
06/08/15 08:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats crank HP... also thats probably a bit high BUT you didnt give elevation and DA... I took a average to get those numbers.... might be closer to 500 hp
[Re: fed]
#1844462
06/08/15 08:34 PM
06/08/15 08:34 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
-65Valiant 2910Lb with a ironheaded smallblock. How much HP to run low 10s? What do you consider low tens. The Wallace Racing calculator says it takes 542 flywheel horse power to run a 10.20 at 2910 lbs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1844535
06/08/15 09:57 PM
06/08/15 09:57 PM
MR_P_BODY
-65Valiant 2910Lb with a ironheaded smallblock. How much HP to run low 10s? What do you consider low tens. The Wallace Racing calculator says it takes 542 flywheel horse power to run a 10.20 at 2910 lbs. I have found that the Wallace numbers tend to run higher than needed... by about 25 HP.... also I am using 10.0 as low 10s
[Re: MR_P_BODY]
#1844557
06/08/15 10:24 PM
06/08/15 10:24 PM
D-50
North, Alabama
-65Valiant 2910Lb with a ironheaded smallblock. How much HP to run low 10s? What do you consider low tens. The Wallace Racing calculator says it takes 542 flywheel horse power to run a 10.20 at 2910 lbs. I have found that the Wallace numbers tend to run higher than needed... by about 25 HP.... also I am using 10.0 as low 10s That is disappointing. That means I am putting less HP to the track than I thought. I was already about 30 hp short according to them.
[Re: D-50]
#1844575
06/08/15 10:38 PM
06/08/15 10:38 PM
MR_P_BODY
-65Valiant 2910Lb with a ironheaded smallblock. How much HP to run low 10s? What do you consider low tens. The Wallace Racing calculator says it takes 542 flywheel horse power to run a 10.20 at 2910 lbs. I have found that the Wallace numbers tend to run higher than needed... by about 25 HP.... also I am using 10.0 as low 10s That is disappointing. That means I am putting less HP to the track than I thought. I was already about 30 hp short according to them. I dont like the numbers either.. but it is what it is.. it only takes like 630 hp to run my numbers(8.90 at 152)
[Re: fed]
#1845749
06/10/15 02:24 PM
06/10/15 02:24 PM
fed
Stockholm, Sweden
That is with driver included. I have a 340 at 640 HP and a RB with 720HP but the car has a 8 3/4. I dont think it will like a transbreak after thos engines. It had a nice 340 W-2combo but the hyd cam has gone flat! Picked up an original -70 crank yesterday What brand/type for engine bearings? Fullgrove or 3/4?
[Re: AndyF]
#1845906
06/10/15 05:54 PM
06/10/15 05:54 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Does 2910 lbs include the driver? If so that is a fairly light car. With what appears to be a pretty gutted early A-body, with a smallblock........and you guys think 2900lbs is light?.......Wow, some must have some real tanks........LOL!!! Monte
[Re: fed]
#1845916
06/10/15 06:07 PM
06/10/15 06:07 PM
fed
Stockholm, Sweden
Fiberglass fenders, doors, hood, reardeck. No innerfenders and alu firewall. original floors, steeltubs, eightpoint rollbar, steelheads on Engine. Frontend all original, discbrakes.
[Re: Monte_Smith]
#1845978
06/10/15 06:51 PM
06/10/15 06:51 PM
MR_P_BODY
Does 2910 lbs include the driver? If so that is a fairly light car. With what appears to be a pretty gutted early A-body, with a smallblock........and you guys think 2900lbs is light?.......Wow, some must have some real tanks........LOL!!! Monte I built my car to be light... its 2405# with driver at the line.. the power is what it is... yeah we all want to say 700hp+ but it isnt happening..... be real
