Restoration Batteries
#1823258
05/10/15 09:30 AM
05/10/15 09:30 AM
Posts: 156 Central KS
Fred_Gilmore
Central KS
I received an email from TurboStart on Friday explaining a relationship they have formed with Remy Battery. It looks like the TurboStart restoration batteries are going to be available for a limited time. Here is a link if you guys want to investigate the offer. I have not talked with Remy but will on Monday and see if I can work something with them to get us a better deal. I'll keep you posted.... Fred Gilmore http://www.remybattery.com/turbostart.aspx
Re: Restoration Batteries
[Re: Pynzo]
#1825093
05/12/15 04:56 PM
05/12/15 04:56 PM
Posts: 4,751 Motor City
6PKRTSE
Motor City
If you have an old one still laying around, I have done this twice now. I cut mine apart once it died & added a Odyssey light weight racing battery inside. Not a race car, but it did go from like 54 lbs down to 18 lbs. It has more cranking amps & turns over much faster now than the re-pop Mopar red top batteries do.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mickm]
#1825804
05/13/15 02:32 PM
05/13/15 02:32 PM
6PKRTSE
Motor City
Yes, it was messy. I wore gloves & safety glasses due to the acid. I just set the battery upside down in my oil change pan which is one of the larger pans obviously. Cut the bottom off with my cut off wheel, pulled out all of the guts. Drilled & tapped the bottom of the original lead posts. Bolted some 12" long battery cables to them & then ran the other end to the new racing battery & shoved it all in. Works great, I am on my 4th or 5th summer now on this same battery.
It took about 1-1/2 to two hours to do, with cleanup....
[Re: partsforsale]
#1827498
05/15/15 08:00 PM
05/15/15 08:00 PM
Posts: 28,740 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I also gutted one. Drained and Cut the top off neat. Then I drilled and taped the post I can go 2 ways that way, to hook up cables. I can use the washers and post as shown, and use a top post terminal. Or a cable end with washer and bolt. I did detail the plastic box. like you would do a yellowed head lamp. And added some angle plastic I had with epoxy to the lid to keep it in place. Looks like angle iron but is plastic ![](http://i234.photobucket.com/albums/ee87/fast340six/Battery/PB040007Modified.jpg) ![](http://i234.photobucket.com/albums/ee87/fast340six/Battery/batterytop.jpg) ![](http://i234.photobucket.com/albums/ee87/fast340six/Battery/PB040008.jpg) ![](http://i234.photobucket.com/albums/ee87/fast340six/Battery/PB040004.jpg) As you can see with the red top caps it was not yet 100% polished up yet
[Re: 340SIX]
#1827596
05/15/15 11:12 PM
05/15/15 11:12 PM
Posts: 1,956 South Bend
John Brown
South Bend
Every once in a while hollow "display batteries" come up on ebay. I used to call on parts stores and garages while working as a sales rep and found quite a few that the owners were willing to part with at reasonable prices. I have converted several of them with Odyssey batteries or the like.
[Re: Fred_Gilmore]
#1828801
05/17/15 09:12 PM
05/17/15 09:12 PM
Posts: 3,017 Long Island, NY
shakerjoe
Long Island, NY
I received an email from TurboStart on Friday explaining a relationship they have formed with Remy Battery. It looks like the TurboStart restoration batteries are going to be available for a limited time. Here is a link if you guys want to investigate the offer. I have not talked with Remy but will on Monday and see if I can work something with them to get us a better deal. I'll keep you posted.... Fred Gilmore http://www.remybattery.com/turbostart.aspx just curious Fred if anything else came up as far as a better deal, thanks
[Re: shakerjoe]
#1830902
05/20/15 03:20 PM
05/20/15 03:20 PM
Posts: 1,955 Olympia, Washington
tallzag
Olympia, Washington
Summit used to have a great price on these but everybody is out now. Just bought a couple from Antique Auto Battery and they have held up well so far. Have had trouble with the gel cell Turbo Start ones, only get a year or two out of them.
Rocket Restorations
[Re: 6PKRTSE]
#1830914
05/20/15 03:39 PM
05/20/15 03:39 PM
Posts: 6,586 SE Pa.
LimeliteAero
SE Pa.
If you have an old one still laying around, I have done this twice now. I cut mine apart once it died & added a Odyssey light weight racing battery inside. Not a race car, but it did go from like 54 lbs down to 18 lbs. It has more cranking amps & turns over much faster now than the re-pop Mopar red top batteries do. Are you securing the new battery in any way inside the shell? Or are the cables stiff enough to hold it from moving around too much? Thanks!
[Re: moparmatt0]
#1842805
06/06/15 10:55 AM
06/06/15 10:55 AM
Posts: 29,682 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Which battery is correct for a 70 cuda 440-6 It depends, so the only way to know what it came with would be to check the battery section of your broadcast sheet if you have one for the car.
[Re: RP's R/T's]
#1842905
06/06/15 02:30 PM
06/06/15 02:30 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
OK, is it just me, or does it seem that just selling the empty Battery Box and creating a kit (inner cables, foam, etc) so that anyone could make their own battery as shown would be perfectly fine for 99% of us?
Why deal with a battery company?
Make a box that snaps together and I can go to a local store and buy a battery myself.
Fred, do you own the tooling for the empty box and caps? I'm sure if someone does do that they will charge $500 for it.
