Green Axle Bearings -8 3/4- Ok to use on C body wagon??? #1844313
06/08/15 04:35 PM
06/08/15 04:35 PM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
I have a 65 Chrysler New Yorker 9 pass wagon in need of axle bearing replacement. Car has 8 3/4 rear end in it....Would the "Green" non adjustable axle bearings work for this application? Hope to put quite a few miles on the car this summer.....Or should I stick with the factory style ones with the adjustment? Thanks in advance thumbs
Curator at Adams County Speed Shop
Re: Green Axle Bearings -8 3/4- Ok to use on C body wagon??? [Re: 340man4ever] #1844331
06/08/15 05:14 PM
06/08/15 05:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I know what I'd do and it's not green.
Re: Green Axle Bearings -8 3/4- Ok to use on C body wagon??? [Re: 62maxwgn] #1844332
06/08/15 05:16 PM
06/08/15 05:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Agreed
I have mechanical Aptitude.
I can screw up anything.
Re: Green Axle Bearings -8 3/4- Ok to use on C body wagon??? [Re: 340man4ever] #1844355
06/08/15 06:04 PM
06/08/15 06:04 PM
Creston, Iowa
3
Creston, Iowa
Sounds like the stock set up is the way to go....Thanks guys..........
