Thanks savoy and John for the replies.
As best I recall, the speedometer pinion gear and cable housing are in / attached to the NP 205 Transfer case, but the truck is not nearby at the moment for me to verify.
I don't know if that makes a difference or not?
The truck has a NP 435 transmission and a NP 205 xfer case.
I have a personal copy of the 1974 Dodge Truck Factory Service Manual, and the Speedo chart indicates:
"Gear Teeth = 5" and "Pinion Teeth = 14" when used with 4.10 ring/pinion gears and 9.5" x 16.5" tire combination or,
"Gear Teeth = 5" and "Pinion Teeth = 15" when using either 8.00" x 16.5" or 8.75" x 16.5" tires and 4.10 differential.
And, of course, I have 33-inch tires, not 9.50 x 16.5's.
According to TireRack.com, 9.50" x 16.5" tires would be around 30 1/2" diameter.
I found a website for speedometer pinion gears, but not certain if this was THE one indicated in the reply post or not?
http://www.transmissioncenter.org/speedometer_gears_for_dodge_and_jeep.htmIn any event, appreciate the help.
