Re: 67 Valiant budget built to race 2015
[Re: Tomswheels]
#1845079
06/09/15 04:34 PM
06/09/15 04:34 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
How close did the rears get to the target number I gave you Tom? Unsure what # you mean.... Unless it was 1, as in 1st place is the target... ....springrate.
[Re: Tomswheels]
#1867811
07/10/15 04:21 PM
07/10/15 04:21 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Already gave ya a vote, im gonna put something together to next month.
Mopar to the bone!!!
[Re: Tomswheels]
#1867879
07/10/15 07:33 PM
07/10/15 07:33 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
Thanks! Ya I was limited to old footage I had on computer, I'm hoping to get much more hi tech another month with the Valiant!
[Re: Tomswheels]
#1869013
07/12/15 08:41 PM
07/12/15 08:41 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
Thanks guys. The Valiant is handling nicely, but I'm going to keep pushing to find ways to get it to he next level. Scored this set of Rotiform Forged 18x10.5 wheels off Craigslist for $400, because one had a small crack at the bead and one had a small dent. They weigh 20 lbs, which is 7 lbs less than my current front wheel, and 9 lbs less than each of my rears... That is a nice amount of weight dropped and for the money spent averaging under $200 per corner, sell off the old wheels and I bet you are at even money. Now since you dropped that kind of weight have you noticed better response from the car into and out of the turns? As well as the stopping distance can you go deeper into the corners now?
[Re: Tomswheels]
#1871300
07/15/15 11:53 PM
07/15/15 11:53 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Congrats Tom!! What are you going to spend your money on??
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1871303
07/15/15 11:59 PM
07/15/15 11:59 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Congrats Tom!! What are you going to spend your money on?? He won? I believe he was going to get new T-bars.
[Re: Tomswheels]
#1881009
07/29/15 06:56 PM
07/29/15 06:56 PM
Posts: 351 Spokane, WA
48Heap
Spokane, WA
So why are you running the earlier sway bar?
I thought the later one was superior in that it was tucked up better being inside the k-frame, and the shorter arms made the bar effectively stiffer than the early bar. Read the whole thread but I don't remember reading anything about why to run that one.
Nice car, BTW! Well done.
15 Chrysler 200S 3.6 15 Challenger R/T 6M STP 74 Duster 360 -> original 4 speed car
a.k.a. DionR
[Re: Tomswheels]
#1881074
07/29/15 08:27 PM
07/29/15 08:27 PM
Tomswheels
Escondido CA USA
Actually I had forgot this had happened, I ordered the Hotchkis kit before I had a 73+ K member, so I ordered the older car kit. After the steering wouldn't clear the Dougs Headers using the old K and suspect slant six conversion motor mounts, I switched to a 73+ spool mount V-8 K. Dan made the older sway bar work on the new K. I have since heard that since it's bigger and mounts in a different location the 72 and earlier sway bar may actually be stiffer anyway.
[Re: Tomswheels]
#1881472
07/30/15 12:19 PM
07/30/15 12:19 PM
48Heap
Spokane, WA
Actually I had forgot this had happened, I ordered the Hotchkis kit before I had a 73+ K member, so I ordered the older car kit. After the steering wouldn't clear the Dougs Headers using the old K and suspect slant six conversion motor mounts, I switched to a 73+ spool mount V-8 K. Dan made the older sway bar work on the new K. I have since heard that since it's bigger and mounts in a different location the 72 and earlier sway bar may actually be stiffer anyway. Ah, got it. Thanks!
a.k.a. DionR
