Fuel Cell Vent Line - Question/Poll #1842776
06/06/15 09:56 AM
06/06/15 09:56 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
How do you route the vent line from your fuel cell and why?
1) Loop in top of line
2) Loop in bottom of line
3) Loop on the side of the tank
4) No loop
Vent Line
single choice
Votes accepted starting: 06/06/15 09:56 AM
Re: Fuel Cell Vent Line - Question/Poll [Re: 440Jim] #1842786
06/06/15 10:17 AM
06/06/15 10:17 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
First, does the tank in question have a "rollover vent valve"?
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Fuel Cell Vent Line - Question/Poll [Re: 440Jim] #1842806
06/06/15 10:55 AM
06/06/15 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
As soon as I get some more line in stock here..I'll
do what I normally do on the vent.. it takes more line
but it also has a roll over feature.. I I come up from
the tank then go either left or right but go as far as
I can then do a 180* and go all the way across the car
then back to some place thats out of the way and drop
the line down below the bottom of the tank... I do this
even if it has a roll over valve
EDIT
The reason I do it this way is that it always has
a high loop above the tank even in any condition..
that high loop keeps fuel from draining
wave
Re: Fuel Cell Vent Line - Question/Poll [Re: jcc] #1842821
06/06/15 11:28 AM
06/06/15 11:28 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I will ask him.
Even if he doesn't, since the line exits below the floor of the tank, if the car is inverted, the end of the hose will be above the tank and I don't think that could flow. But if the car comes to rest on its left side, the hose end will be below the tank...
JCC, how do you do it with and without the rollover valve?
Re: Fuel Cell Vent Line - Question/Poll [Re: 440Jim] #1842832
06/06/15 11:41 AM
06/06/15 11:41 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have always seen it with the loop on the bottom. I have the Valiant set up like that.
My Avenger is loop on the side because I run the vent to a scoop for pressure going down the track.
Re: Fuel Cell Vent Line - Question/Poll [Re: 440Jim] #1843017
06/06/15 05:55 PM
06/06/15 05:55 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Rollover valve and no loop. I also stuck a small fuel filter at the end of my hose outside just to keep any dust or dirt from going up into the hose. I'm probably over thinking this but if for any reason liquid would gather in the loop then it would be more like a sink trap and there would be no venting.
Re: Fuel Cell Vent Line - Question/Poll [Re: shorthorse] #1843025
06/06/15 06:14 PM
06/06/15 06:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
This is true. I just have a roll over with the hose arched & going through the trunk floor.
Re: Fuel Cell Vent Line - Question/Poll [Re: 440Jim] #1843126
06/06/15 09:38 PM
06/06/15 09:38 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
No loop. Just a upside down "J" from cell to front of cell in floor using aluminum tubing.
Nautilus Racing-
Re: Fuel Cell Vent Line - Question/Poll [Re: Chris2581] #1843153
06/06/15 10:34 PM
06/06/15 10:34 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I did 2 loops above the cell and then to a rubber hose with a fuel filter on the end.
I will have to take a picture if interested.
Works great.
Re: Fuel Cell Vent Line - Question/Poll [Re: 440Jim] #1844382
06/08/15 05:36 PM
06/08/15 05:36 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
No loop, rollovervalve and a little tankfoam in the bulkheadfitting.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Fuel Cell Vent Line - Question/Poll [Re: fed] #1844436
06/08/15 07:03 PM
06/08/15 07:03 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Similar to the bottom picture, only tighter to the tank and to the right side. the bottom of the vent hangs down below the tank. That way the only way fuel can run out the vent is if the car is turned over and laying on the right side.
Brian
