'67 Fury, 383-2bbl, all stock.
Once I start it, there's a bit of a putt-putting at slow idle, with noticeable carbon spots on the ground after five minutes or so. I've pulled several plugs, and they all look fine. I did a full tune-up about 5k ago--plugs, points, rotor, cap, set timing.
A friend who's worked at dealers his whole adult life says I should have put a MP electronic ignition on it when they were still available. But, of course, they aren't available anymore. So I'm looking for alternatives. Again, this is a stock 383, so I don't see the need to go with some high-dollar race setup. I'm leaning toward Pertronix, or maybe one of those setups D.U.I. offers. Simple is best. This thing's getting a factory dual-snorkel air cleaner one of these days, so clearing the passenger-side tube on that is a consideration.
Thanks!
