Help! Holley HP question
#1841691
06/04/15 08:47 PM
06/04/15 08:47 PM
Posts: 183 Macon, Missouri
TJ2
Macon, Missouri
My carburetor knowledge is extremely limited, and trying to help a good friend of mine here. He has an 830 Holley HP 80509-1 on his stroker small block. This carb has been on the engine for a good 4 yrs, and has always ran real well. He just started having an issue with it. Out of the clear blue, it all of a sudden doesn't want to idle.
Started to investigate, so he took the air cleaner off, and also took off the stud that goes in the center of the carb which holds the air cleaner on. Fired it up with these two items removed, and now the engine now idles fine, just like it used to before it started acting up. Put the air cleaner stud back in the hole, and the idle goes crappy...to where the engine dies.
Took the air cleaner stud back out, fired the engine up. Idles fine. Placed finger over the hole where the air cleaner stud goes, and there is strong vacuum there at idle and also at any engine rpm. Revving the engine to any rpm and placing your finger over the hole makes an immediate difference in how the engine runs.
What's going on with this carb, that there is vacuum where the air cleaner stud screws in, and that this is effecting how the engine runs and idles?
Thanks in advance! TJ2
Re: Help! Holley HP question
[Re: TJ2]
#1841720
06/04/15 09:34 PM
06/04/15 09:34 PM
Posts: 1,532 off the grid
340B5
off the grid
I don't know it all either, but I think there's an Idle adjustment screw in that hole just like the Demon carbs.
Yeah, it's got a smallblock.
[Re: shorthorse]
#1842078
06/05/15 01:05 PM
06/05/15 01:05 PM
BradH
That's a good one. I just checked Holly's instructions for the HP 80509-1 on-line. There is no mention of a center adjustment screw like the Demon has. The air bleed screw under the air cleaner stud is a feature that wasn't introduced until the later aluminum "Ultra HP" 4150 carbs. Those are the 8080# series, such as the 80805 850 version.
[Re: BradH]
#1842611
06/06/15 12:08 AM
06/06/15 12:08 AM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Somehow or another your carb has gone rich. As suggested, check the air correctors to make sure something is not clogged. Alternative of the loose power valve also makes sense. Essentially, when you removed the stud you opened up the throttle introducing more air which it clearly needed.
Kind of doubt all the air correctors clogged at once, so maybe a quick check of the power valve is in order, or as I think someone suggested is the needle stuck open? Think you would see a stuck needle coming out the bowl vent though.
Quick way to tell if you have the air bypass is to look and see if there are 4 holes in the boss around the air cleaner stud. This comment is more for reference as I doubt you have that.
The old 950 HP I used to have the threaded hole went all the way through. When the stud was removed the idle sped up, which is what you would expect.
Good luck.
Best regards, Dave
