I have a 69 GtX, I didn't have any pictures. My quarter glass took two bolts with a larger captive washer, four rubber bushings and two rubber washers to hold the glass to the bracket on the regulator. I believe the bolts were around 1/4 x 20 by about 1 to 1 1/2 inches long. They have a 1 inch captive washer behind the bolt head. The rubber bushing should fit in the holes in the glass and allow the bolt to pass thru. Keeps the bolt threads away from the glass. Rubber washer goes on each side of the glass and keeps the bolt head and bracket face from contacting the glass. Measure the threaded holes in your regular to verify the bolt size. Repeat for the other side.
