Ignition problem with s/6 #1840104
06/02/15 10:49 PM
06/02/15 10:49 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
Did tune up on 71 dart w/6. Car wasn't running when I got it. Have power going to coil, but car won't start. Any suggestions?
Re: Ignition problem with s/6 [Re: kimber] #1840125
06/02/15 11:08 PM
06/02/15 11:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Got fire to the plugs? Power to the coil with ignition in start position or in run or both?
Re: Ignition problem with s/6 [Re: stumpy] #1840251
06/03/15 02:37 AM
06/03/15 02:37 AM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
No fire to plug. Fire in start and run to coil.
Re: Ignition problem with s/6 [Re: kimber] #1840287
06/03/15 05:36 AM
06/03/15 05:36 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Did you pull the distributor out to put points in it? It is real easy to break the gear off.
Re: Ignition problem with s/6 [Re: slantzilla] #1840634
06/03/15 04:51 PM
06/03/15 04:51 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Take off your distributer cap and see if the rotor turns when you crank the starter.
The distributer gears are plastic and break from old age. Napa carries new ones.
Re: Ignition problem with s/6 [Re: kimber] #1840685
06/03/15 06:03 PM
06/03/15 06:03 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
Thanks for all the suggestions. Pulled distributor found wide that goes to coil was partially on and was grounding itself. Fixed it, car cranked. Now just need to fine tune. Thanks again everyone. Mopar people are the best!
