I've got an easy ? for the early A guys
#183962
01/04/09 07:35 PM
01/04/09 07:35 PM
Can any of you early A-body guys post a couple of pics of a 1966 Z-bar with a Ruler or Tape measure next to it? I've got the Z-bar out of my old drag car, but it has been broken-welded-gusseted-welded a couple times, and it doesn't look like a factory piece anymore. I'd re-use it but when they fixed it the first time they screwed up, and the geometry is wrong. It nearly wore off the stud on the Z-bar. It did wear a chunk out of the clutch rod, and it wored the back side of the ball stud (frame side) FLAT. So I'm just going to replace the thing. I have 3 or 4 of them and one looks pretty close. I'm hoping to get a nice pic to verify. Thanks in advance.
Re: I've got an easy ? for the early A guys
#183963
01/04/09 08:07 PM
01/04/09 08:07 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
I just got a 66 four speed car but haven't pulled the motor yet. I don't know if I can get a good pic with the exhaust manifold in the way. If no one comes thru for you I'll see what I can do.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: RapidRobert]
#183965
01/04/09 08:30 PM
01/04/09 08:30 PM
fyi the /6 & the V8 ones are different on the length of the main shaft & possibly(but not sure) the clocking of the two arms
Can't believe I left that piece of info out. The car is a 273 4-barrel car.
#183966
01/04/09 10:57 PM
01/04/09 10:57 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Just call Brewers, I'm sure they'll give you the measurement.
[Re: dart4forte]
#183967
01/05/09 08:16 PM
01/05/09 08:16 PM
I still need to see a pic, or reference drawing. Does the lower arm have a notch where itwould make contact with the firewall? Anyone?
#183968
01/05/09 08:24 PM
01/05/09 08:24 PM
dart4forte
Mesa, Arizona
I'll have to take a picture of my set up
[Re: dart4forte]
#183969
01/08/09 09:12 PM
01/08/09 09:12 PM
#183970
01/08/09 10:30 PM
01/08/09 10:30 PM
RapidRobert
they generally hit from where the vertical firewall starts to slope, from that point down to the pinchweld or slightly below it. With my stock car I just beat it in with a very BFH which would not be an appropriate plan of action for you, so hopefully someone will chime in with pics.
