Re: coolant overflow after shutdown
[Re: smos001]
#1838165
05/31/15 07:46 PM
05/31/15 07:46 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
You may need to lower the coolant a bit more. I leave it just above the tubes. Kevin
71 gtx.....
[Re: smos001]
#1838171
05/31/15 07:50 PM
05/31/15 07:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Normal, that is why there are overflow tanks on newer vehicles. In older ones that just puked on the floor, it'd stop puking when the level got low enough and you'd have air in the top of the radiator.
[Re: Supercuda]
#1838251
05/31/15 09:53 PM
05/31/15 09:53 PM
RapidRobert
OT & this might make it kick out a bit more but just me I would highly suggest going to a 180 stat for faster getting out of the high wear "warmup" zone.
[Re: RapidRobert]
#1838255
05/31/15 10:01 PM
05/31/15 10:01 PM
Posts: 13,621 md
mopars4ever
md
Did you add a catch bottle or a coolant recovery tank? A coolant recovery tank will always have antifreeze in it and it will need a coolant recovery type cap. Also the radiator would be filled to the top.
[Re: smos001]
#1838570
06/01/15 12:07 PM
06/01/15 12:07 PM
Supercuda
About to go away
About to go away
up yours
I think it's called the siphon effect. If the cap fails to seal after it vents and the overflow is lower than the radiator it will siphon coolant out until the levels equalize.
[Re: jlatessa]
#1838673
06/01/15 01:39 PM
06/01/15 01:39 PM
Posts: 566 WA
tman
WA
In a similar vein, I'm mounting a recovery tank and two-way type of radiator cap, can I mount the recovery tank at any level, i.e. lower than the top of the rad?
Thought I remember someone saying no but I don't see the reasoning.
Thanks, Joe Yes, it should work as long as the hose is at the bottom of the tank.
