Fuel Filter/Vapor Separator install/Fuel lines #1837899
05/31/15 12:26 PM
05/31/15 12:26 PM
Eastern, USA
Charger43 Offline OP
Eastern, USA
Anyone know where you install a Fuel filter/Fuel Separator
and buy a fuel line kit (fuel pump to Carb.) for [color:#336666][/color]a 69 Charger R/T
Email:charger4@ptd.net
Re: Fuel Filter/Vapor Separator install/Fuel lines [Re: Charger43] #1838810
06/01/15 04:25 PM
06/01/15 04:25 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
where you install it? I believe its off the most forward bolt of your fuel pump. I have one to install myself....your fuel filter...I get the big metal can ones from FRAM and I drilled a hole and attached a hose clamp on the subframe connector next to the K-Member to help cool the fuel as it travels to the front of the car.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Fuel Filter/Vapor Separator install/Fuel lines [Re: Charger43] #1839119
06/01/15 08:11 PM
06/01/15 08:11 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
