Re: Vacuum Pump Vs. Oil Preasure ?? [Re: camastomcat] #1837132
05/30/15 03:33 AM
05/30/15 03:33 AM
ohio
dragon Offline
dragon  Offline
ohio
had the same problem with a old pro truck motor 358 the oil psi was great with out vaccum hook up vac oil psi drop check every thing called every body never found problem left vac off and raced with out vac like to know what you find still tring to figure it out
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: Crizila] #1837191
05/30/15 11:01 AM
05/30/15 11:01 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By Crizila
assume you are measuring crankcase vacuum in " of water?
Water column (inch) is not normally used in these type applications as it is a much smaller unit of measure. 1 psi equals about 27.7 wc (inches), where as Mike posted 1 psi equals just a touch over 2" of mercury (Hg).
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: gregsdart] #1837209
05/30/15 11:26 AM
05/30/15 11:26 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Originally Posted By gregsdart
If you find that the gauge was/is accurate, then there might be enough restriction or an air leak on the inlet side of the pump to cause this. I would pull all those items apart and make sure you have pan to pickup clearance, no air leaks, either above the oil level or somewhere close.
This is what Im thinking.... the pan is coming off it today and the pickup is getting inspected.
Something just dosent make sense here smile
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: MR_P_BODY] #1837219
05/30/15 11:36 AM
05/30/15 11:36 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Originally Posted By MR_P_BODY
Originally Posted By WH23H6
Originally Posted By B3422W5
Yep, first step is to try and isolate the issue. Try running the motor first without the pump bring employed .
From what I understand( and I have never run a vacuum pump) your oil pressure is going to come down directly related to how much vacuum your pulling. Pulling 15 vacuum should lower oil pressure roughly 15 pounds.
I am kinda surprised you seem fine with having over 100 pounds of oil pressure cold/ 90 hot.That is WAY to high in my opinion, and counter productive. With tons of 40 weight oil that can't be a positive effect on power output.
Yea... Ive been told that its too much oil pressure..... robs HP... now go ask how much Oil pressure a pro mod runs.... they have shut offs if it drops below 160 PSI.... I'll eat the HP to save this engine.... smile
Some racers search for every avenue of HP savings... and I can't argue that, but at the end of the day... too much Oil pressure never hurt an any engine... but not enough has hurts lots!
I dont build pro mod engines so I cant say what
they run for oil pressure... the next thing is..
did you build a pro mod engine... I'm guessing.. no
so in my way of thinking is.. dont look at their builds
unless yours is like it... if thats the true case and they
run 160+ oil pressure then they COULD be pulling high vac
which would reduce the oil pressure
wave
I simply meant that the excessive oil pressure is by choice. And I don't think it has anything to do with this problem. This exact combo has bee fine and living well for a number of years. I realize that lots of people think 100lbs is excessive and detrimental to HP.... while I agree that the added "windage" from that oil pressure may rob a few HP, I believe that the added pressure decreases the odds of scuffed metal to metal should the something happen.. IE: sudden temporary loss of pressure should the pump cavitate in a wheel stand or when vacuum tries to overtake it after lifting at the big end.
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: LSP] #1837224
05/30/15 11:42 AM
05/30/15 11:42 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Sounds like you're not in a situation where you're looking for every last hp, so why the vacuum pump?
Those swinging pick ups tend to not be 100% air tite, so unless you're sure the oil level keeps it submerged at ALL times, might be something to look at.
Im not looking to squeeze everything out of this combo... its a big inch motor that shifts at 6800 max and spins at 7000 max. It will go 7600 with ease but like everything, tighter you wind the elastic, more chance that it snaps smile The vacuum pump is needed because it does have a very low drag ring combo. The engine will run fine (idling) without it... but will probably tend to want to pass some oil without the help of the vacuum pump to keep the rings tight. Passed oil = detonation = cracked piston pin bosses ect...
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: camastomcat] #1837227
05/30/15 11:47 AM
05/30/15 11:47 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Originally Posted By camastomcat
Just out of curiosity, what heads? Do they need drain backs? Is oil gathering in the puke tank? Too much oil on the top of the heads? My vacuum pump scavenges about 10-15 lbs at 7800 RPM and 14 inches. That would be from 95 to 82 lbs through the lights. The only reason I know that is because I have a racepak and left the valve covers loose one time.
Funny you should ask that.... they are stage 5 Millenium heads. And after racking my brain for any changes I made during this winters freshen up, I remembered that I installed external rear drain backs on them this winter. My thought was to double the speed at which the oil was returned to the pan.... the drain back runs from the rear of the head to each side of the oil pan. This is one of the only changes that was made to the combo. I purchased some caps and just for my own santity, Im going to block them off and try it. Id bet the farm that they have nothing to do with this problem.... but ??
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: justinp61] #1837247
05/30/15 12:41 PM
05/30/15 12:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks. I figured, but just had to ask because of how weird the problem is. After reading some of the posts, I guess it aint that weird. bow
Fastest 300
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: WH23H6] #1837912
05/31/15 12:38 PM
05/31/15 12:38 PM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey Guys,
UPDATE!!
So after trying a bunch of things... and doing some brain picking... we removed the oil pan to inspect things yesterday. What was noticed (by my brother / crew chief:) ) was that in one part of the pickup swing, the pickup became pretty close to the bottom of the oil pan. Finding nothing else, we decided to go with this as a possible issue. We managed to raise the pickup slightly by elongating the holes in the side of the oil pan and grinding some off the Milodon pickup bar inside. This was needed to clear the centre tube in the oil pan for the centre ink. After all modifications, we now have about 1/4" clearance between the pickup and pan for the full swing. Back together.. fresh oil... oil pressure stable through full vacuum range now.
Best guess is that as the vacuum increased and the oil pressure increased, it was just enough to pull the swinging pickup too close to the bottom of the pan... thus killing the oil pressure.
Thanks for all the input guys... have a great season!
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: WH23H6] #1837931
05/31/15 01:00 PM
05/31/15 01:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to hear you found your issue.. at least a
possible one... you dont want or need much vac at
idle and you want to limit it to about 12"-14" hg
wave
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: WH23H6] #1838041
05/31/15 04:04 PM
05/31/15 04:04 PM
AndyF Offline
AndyF  Offline
Sounds reasonable. It wouldn't take very much vacuum to oil can the bottom of a flat pan if it wasn't well supported. If the pan was being sucked up and blocking the inlet then you would lose oil pressure. I'd say this falls into the "weird" category. Glad you found the problem. I bet your old pump was fine also.
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: WH23H6] #1838057
05/31/15 04:36 PM
05/31/15 04:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Glad you found it. Hope no peripheral damage.
Fastest 300
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: AndyF] #1838369
06/01/15 01:19 AM
06/01/15 01:19 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
lol... hope not ! hate to think I Pissed away $800.00 on that KB pump ! But at some point Im going to try the old Milodon and see for sure... test and tune this weekend coming... hoping for a low 8.90s or may a 8.80s ... if I have the balls to stretch the old girls legs out a little smile
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: WH23H6] #1838374
06/01/15 01:25 AM
06/01/15 01:25 AM
AndyF Offline
AndyF  Offline
Well oil pumps don't really go bad unless they are really trashed. Take the cover off of the Milodon pump and pull the rotors out and look at them. If they aren't all galled up then the pump is most likely just fine. You were probably fighting the issue with the pan being too close to the pickup the entire time.
Re: Vacuum Pump Vs. Oil Preasure ?? [Re: AndyF] #1838380
06/01/15 01:32 AM
06/01/15 01:32 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
On the bright side.... Im 1 step closer to having a backup motor if that old pump is good.... couple of more dollars and im good! hahahah
