Re: / 6 engine problem
[Re: 71_deputy]
#1836544
05/29/15 11:22 AM
05/29/15 11:22 AM
RapidRobert
I'd (1) pull valve cover/spark plugs (2) turn eng dampener till #6 rocker arms are both moving & are at the same height (rockover),(actually pushrod height might be more dead on on a mech cam if the gap is adjusted way out of whack) but see how it looks/goes. (3) dampener slit should be within a degree or two of TDC on the timing tab (symmetrical cam) (4) at that point rotor should be pointing to #1 cap terminal (5) if at #6 he's 180 out. With all that crankin he might wanna regoop the cam. EDIT What Swinger said, rocker adj is .010" intake/.020" ex. tho not sure if those are hot or cold specs but if very close then the dist and or cam is phased wrong.
[Re: 71_deputy]
#1836641
05/29/15 01:44 PM
05/29/15 01:44 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Either the lifters are adjusted way too tight and the valves are not closing or it's put together wrong in the timing set area.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
