99 Cummins lift pump questions.
#1836348
05/28/15 11:27 PM
05/28/15 11:27 PM
Posts: 6,679 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I just bought a 99 CTD and it had an occasional stutter in it like it was running out of fuel. Checked lift pump pressure, zero. The pump is still on the side of the engine and it was making no noise so I bought an Airtex E7153 that is a direct fit. As my luck would have it, no pumping from this either. Checked for power, none. I have it connected to a switched 12v source now and it makes 18 psi. Questions are: Where does the stock connector get it's power from? What are the chances it's something easy. I've read it get power directly from the ECM. How much current do one of those gerotor pumps draw? If I have to leave it wired as is I need to have it fused accordingly. It is currently fused at 10 amps which is running it OK but seems a little light to me. Kevin
Re: 99 Cummins lift pump questions.
[Re: Twostick]
#1836401
05/29/15 12:28 AM
05/29/15 12:28 AM
DaytonaTurbo
Manitoba, Canada
Electric fuel pumps don't generally draw much. I don't know how much this one in particular is, however on another install I used a high pressure electric fuel pump. The manufacturer supplied documentation showed the pump drawing 20 amps at max pressure. Max pressure was something like 150psi on an efi system that normally runs 50, which called for around 8amps. Your 10A fuse is probably fine. Bump it to 15 if you're concerned. I just bought the truck in Saskatchewan and I'm planning to stop on the way home at a truck wrecker to source a pyro, fuel and boost gauges.
Kevin
I would do the fuel pressure gauge, but for the rest, save your money. You'll be doing an injector pump soon...
[Re: Twostick]
#1836463
05/29/15 04:01 AM
05/29/15 04:01 AM
Posts: 10,441 A Red State
SNK-EYZ
A Red State
What exactly "fails" on a VP44 anyway?
Kevin Here's the way it was explained to me by the diesel mechanic the installed the VP44 on the 2001 Dodge Cummins I used to own. The VP44 uses the diesel fuel to lubricate and cool it's self. When the lift pump gets weak it doesn't keep the flow required to cool and lubricate the VP44 injection pump. Hence it burns up/wears out. He also said to never have less than 1/3 of a tank of fuel during the hotter months for essentially the same reason. He said that since it's getting some hot fuel recycled back to the tank after lubricating/cooling the VP44 pump with less than that in the tank it's harder for the fuel to cool/lubricate the pump. Is what he said absolutely true? That's a good question, but it kinda makes sense to me. But that's why I'm looking at 12 valve Cummins Dodge trucks right now rather than a 24 valve with the VP44 injection pump. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: Twostick]
#1836594
05/29/15 11:24 AM
05/29/15 11:24 AM
Posts: 13,650 Marion, South Carolina [><]
an8sec70cuda
When I first got my '01 Cummins back in 2011, I put a fuel pressure gauge on it almost immediately. The lift pump had 0 pressure...it had the dealer installed in-tank pump. I replaced it w/ an AirDog system and have been driving it ever since w/ no trouble from the VP44.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
