Priming and painting aluminum engine parts #1835840
05/28/15 10:22 AM
05/28/15 10:22 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hello, I have been using SEM etch primer and some Rustolium etch primer on various parts and I wanted to know if there was a better etching primer out there for engine parts-like Heads and water pumps and intake manifolds..etc.?
Re: Priming and painting aluminum engine parts [Re: GLR] #1835916
05/28/15 12:34 PM
05/28/15 12:34 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I used Eastwoods self etching primer from a spray can before laying on enamel from a gun many years ago and everything except the thermostat housing has held up perfectly. NO ISSUES AT ALL!
The paint I used was Bill Hirsch Engine Enamel.
Re: Priming and painting aluminum engine parts [Re: GLR] #1835922
05/28/15 12:39 PM
05/28/15 12:39 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
O.K. Thank you Dave!...
Re: Priming and painting aluminum engine parts [Re: GLR] #1836084
05/28/15 04:58 PM
05/28/15 04:58 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Looking for a can or gun primer? 7220 MS at Napa is a real good spray bomb etching primer. Spray gun I only use 615 DuPont.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Priming and painting aluminum engine parts [Re: sixpackbee] #1836292
05/28/15 11:06 PM
05/28/15 11:06 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
615 dupont x2 the best
Re: Priming and painting aluminum engine parts [Re: GLR] #1836324
05/28/15 11:47 PM
05/28/15 11:47 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I use PPG DP epoxy primers on engine parts without fail. I like epoxy over etch because etch must have clean almost virgin metal to bite and just does not hold back rust as well.
Have a great day
Iowan
"obsolete is neat"
Re: Priming and painting aluminum engine parts [Re: Iowan] #1836639
05/29/15 01:39 PM
05/29/15 01:39 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
agreed on the ppg dp epoxy. On aluminum parts i also use Bulldog adhesion promoter as well since paint and primers do not stick well to aluminum parts. the adhesion promoter would be the first thing to spray before primer.
Re: Priming and painting aluminum engine parts [Re: 70plymA34] #1836679
05/29/15 02:28 PM
05/29/15 02:28 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
any issues painting heads with it?
Re: Priming and painting aluminum engine parts [Re: Golden-Arm] #1836719
05/29/15 03:22 PM
05/29/15 03:22 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Not at all.
Have a great day
Iowan
"obsolete is neat"
