Seeking info from St Louis plant #1835269
05/27/15 02:22 PM
05/27/15 02:22 PM
SC
V194 Offline OP
V194  Offline OP
SC
With a large archive from Hamtramck does one exist from St Louis? Looking to research a 1969 RR Vert. Or any suggestions on who to contact or where to look?
Re: Seeking info from St Louis plant [Re: V194] #1835601
05/27/15 10:43 PM
05/27/15 10:43 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Not that I know of.
I did document the dismantling of the north and south plants.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/6950217/site_id/1
Re: Seeking info from St Louis plant [Re: convx4] #1835733
05/28/15 01:21 AM
05/28/15 01:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Doug "69CoronetRT" maintains an informal '69 St. Louis Registry, some others dabble in some specifics - What are you looking for/trying to figure out?
Re: Seeking info from St Louis plant [Re: V194] #1835844
05/28/15 10:33 AM
05/28/15 10:33 AM
Welland, ON
Mr. Fix it Offline
Mr. Fix it  Offline
Welland, ON
Check with Patrick66 at the For C bodies Only web forums.
He has a ton of info like what you are asking about.
Re: Seeking info from St Louis plant [Re: 6bblgt] #1835977
05/28/15 02:05 PM
05/28/15 02:05 PM
SC
V194 Offline OP
V194  Offline OP
SC
Looking for a build sheet for a specific car if it exists.
