RPM's at speed - Does this seem about right?
#1835443
05/27/15 06:16 PM
05/27/15 06:16 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
So, for the first time in 10 years, I have a working speedometer. First time since I owned the car. Also just installed a Sun Supertach II.
When I installed the new speedo cable, I also installed a new 33 tooth speedometer pinion. Based on what people here told me, and after looking at some online charts.
So, now that everythings working, at 60mph, I'm turning 3350 rpm.
That's a 318/904, with 3:23 gears and a 25.6" (225/60/15) rear tire. At 70, I'm turning 3800 rpm.
These numbers sound about right? Seems to me the rpm is a little high for the speed, but I guess the gauges don't lie.
Re: RPM's at speed - Does this seem about right?
[Re: MileHighDart]
#1835445
05/27/15 06:18 PM
05/27/15 06:18 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
with a known tire diameter/circumference, and a known gear ratio, and being in any selected gear, one could mathematically determine rpm's, per given speed.
[Re: Golden-Arm]
#1835446
05/27/15 06:21 PM
05/27/15 06:21 PM
MileHighDart
Lyons, CO
sorry, my first post went live before I was done typing. More info there now.
[Re: MileHighDart]
#1835450
05/27/15 06:25 PM
05/27/15 06:25 PM
Golden-Arm
Sunny South Florida
my 518 with 3:91 gives much lower numbers. have to calculate my final drive at tailshaft though. here's a very quick, "down & dirty" calculator, to help you out a bit. CALCULATOR
[Re: MileHighDart]
#1835510
05/27/15 08:29 PM
05/27/15 08:29 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A better speedo pinion accuracy tester is the odometer. It's possible for the odometer to be dead nuts and the speedo to be way off.
[Re: DrCharles]
#1835514
05/27/15 08:30 PM
05/27/15 08:30 PM
MileHighDart
Lyons, CO
Boy am I dumb ! I got to thinking, this tach was on the car when I got it. And the car was a /6 back then. Turns out there's a little hole on the back of the tach, with a small switch in it, that you're suppose to use to switch it from 4cyl, 6cyl, or 8cyl. It was set on 6-cyl Didn't know it was there. When the mounting bracket is on the tach, it covers up this hole with the switch in it. Took it for another drive and sure enough, at 60mph on the phone app, the tach is sitting pretty at 2600 rpm.
[Re: MileHighDart]
#1835527
05/27/15 08:43 PM
05/27/15 08:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Can't beat a cheap fix and I be this never happens to you again, btdt.
[Re: DeMopuar]
#1837988
05/31/15 02:10 PM
05/31/15 02:10 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Just bring a GPS deal in your car and see if it matches your speedo. ! Yes, we are working on old cars but we don't need to use old tools (charts). Take advantage of modern technology, it's cheap and easy to use. Similar to what Kunkel said. Odometer is better, simply because "speedometer is off by 5" is not an accurate observation. (unless the needle is clocked wrong). If yo were off by 5, it would be off by 10 at double the speed and it's would be correct at 0. Speedometers are off by a certain percent. Use a GPS to confirm then adjust up or down by the speedometer gear tooth count.
