Steering Column Linkage #183513
01/04/09 10:45 AM
01/04/09 10:45 AM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
Is this bent? Looks to me like the flat rectangular arm from the main linkage shaft (that connects to the steering column link) is slightly bent...not sure if this is by design...I have no other reference to determine.
Re: Steering Column Linkage [Re: LYNCHROAD69.5] #183514
01/04/09 04:03 PM
01/04/09 04:03 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
yes, it's bent
Re: Steering Column Linkage [Re: AARCONV] #183515
01/04/09 07:56 PM
01/04/09 07:56 PM
Massachusetts
Massachusetts
yes, it's bent
I should have stated this better...to rephase my question: is is supposed to be bent or should it be straight?
Re: Steering Column Linkage [Re: LYNCHROAD69.5] #183516
01/04/09 11:07 PM
01/04/09 11:07 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Looks like it needs to be straight. I found this picture when I was mocking up all the pieces to see if I was missing anything. Not the best detail shot but it does appear that the part is straight. Hope this helps.
68 Hemi Road Runner
Re: Steering Column Linkage [Re: LYNCHROAD69.5] #183517
01/05/09 10:06 PM
01/05/09 10:06 PM
florida
P
PJM Offline
PJM  Offline
P
florida
Mine has the exact same offset.
Re: Steering Column Linkage [Re: PJM] #183518
01/05/09 10:37 PM
01/05/09 10:37 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I just went out to the garage to verify what I had and mine is perfectly straight. With the bend or offset your bracket has, it will make the clearance from the shifter rod (that mounts inboard of the shaft arm) to the exhaust pipe really close. On my car the straight shaft arm only gives me about .5" from the shifter rod to the pipe. I know the exhaust is different between the Hemi and RB but I think that the exhaust pipe run is similar in that area under the car.
