Re: Tubular UCA options
[Re: brads70]
#1837652
05/31/15 12:23 AM
05/31/15 12:23 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Anyone heard/had any issues passing safety inspections with these aftermarket a -arms? Are they certified for on road use? I don't think many parts are regulated by any sort of governing body. Besides lighting [DOT], safety components [DOT?], tires [DOT]..I can't think of much else...except emissions components [EPA]. Consider all the modified 4x4's for a second, there are hundreds of thousands of them throughout the states with aftermarket control arms, tie rods, drag links...even some that are completely home-brewed that go through inspections without hesitation.
[Re: AlexP]
#1837977
05/31/15 01:56 PM
05/31/15 01:56 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
There are some states that Heim joints are ILLEGAL for safety inspection....its been discussed on here before. A lot of jeep guys used to use them and were not passing safety so they had to go back to a bushing style system. The new johnny joints are not in the same class as a heim so they were not restricted. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: AlexP]
#1838012
05/31/15 02:41 PM
05/31/15 02:41 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What states mandate vehicle inspections in the first place?
Mopar to the bone!!!
[Re: brads70]
#1838120
05/31/15 06:19 PM
05/31/15 06:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Anyone heard/had any issues passing safety inspections with these aftermarket a -arms? Are they certified for on road use? I'd assume by the response that they are not? He's in Canada, not sure how attentive the safety inspections are up there, but in TX they are a laugh.
[Re: AlexP]
#1838153
05/31/15 07:26 PM
05/31/15 07:26 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Yep I'm in Canada ( Ontario)I have the Hotchkis arms on now for 4 plus years. I'm just wondering if push comes to shove if these are " legal" ? The MTO ( ministry of transportation) does random inspections are they are relentless on justifying their outrageous salaries and retirement plans. They usually are not mechanics and have very little training/knowledge just lots of authority....
[Re: AlexP]
#1838172
05/31/15 07:51 PM
05/31/15 07:51 PM
Supercuda
About to go away
About to go away
up yours
Bet that authority also says if it doesn't have an official piece of paper saying it is legal and safe, then it is not?
[Re: AlexP]
#1838188
05/31/15 08:14 PM
05/31/15 08:14 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Put the protective booties on there. They will probably never notice that they are rod ends on an UCA.
Now, the Hotchkis tie rods that are rod end...not really sure about being able to hide those. I am not running those. With that being said my Hotchkis sway bars, UCAs, and subframe connectors were nice pieces. Car drives amazing now.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#1838312
05/31/15 11:40 PM
05/31/15 11:40 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
Now, the Hotchkis tie rods that are rod end...not really sure about being able to hide those. I am not running those. With that being said my Hotchkis sway bars, UCAs, and subframe connectors were nice pieces. Car drives amazing now. We have booties for the end links too. Makes them "look" like a standard ball joint.
[Re: AlexP]
#1839225
06/01/15 09:54 PM
06/01/15 09:54 PM
Dan@Hotchkis
THERE ARE NO WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, WHICH EXTEND BEYOND THE DESCRIPTION ON THE FACE HEREOF. ANY IMPLIED WARRANTIES ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. THIS WARRANTY DOES NOT COVER CONSEQUENTIAL DAMAGES, LOSS OF TIME OR REVENUES, INCONVENIENCE, LOSS OF USE OF THE VEHICLE, DAMAGE TO THE VEHICLE OR COMPONENTS OF THE VEHICLE, ANY OTHER TYPE OF CONSEQUENTIAL DAMAGES, OR OTHER INCIDENTAL OR INDIRECT DAMAGES. HOTCHKIS’ MAXIMUM LIABILITY UNDER THIS WARRANTY SHALL IN NO EVENT EXCEED THE PURCHASE PRICE OF THE PRODUCT. Some states do not allow limitations on how long an implied warranty lasts or the exclusion or limitation of incidental or consequential damages and in such states the above limitations or exclusions may not apply. This limited warranty gives the purchaser specific legal rights and the purchaser may have other rights that may vary from state to state. Technical Information Hotchkis Performance makes every effort to ensure that you are provided with the most accurate and up-to-date technical information. However, all technical information is approximate and may vary upon application. Additional suspension components may be needed in some applications, depending upon the make, model, engine and chassis of the vehicle. Hotchkis Performance is not responsible for any consequences resulting from manufacturer’s technical mid-year changes. Hotchkis Performance products should only be installed by a qualified, licensed auto mechanic experienced in the installation of such products. Warranty Claim Procedure: The answer to ALL the following questions should be YES before making a warranty claim: Is the product appropriate to your application? Did you carefully and thoroughly read the instructions provided along with the product? Do you have the original invoice or sales receipt? Is the return date within 36 months from the purchase date? Are you the original purchaser? Was the product properly installed by a qualified, licensed auto mechanic? Has the product been installed on the original vehicle on which it was installed at all times? Is the product unmodified and clean? Is the reason for return a legitimate product defect? If the answer to all these questions is YES, please contact our Customer Service Department at (562) 907- 7757. You will be given a Returned Goods Authorization Number (RGA) valid for 60 days. You will also be asked to ship the product prepaid to our facility. All shipments MUST be (i) prepaid, (ii) include the original invoice or sales receipt, (iii) show the RGA on the outside of the package and (iv) include your name, address, make and model of the vehicle, and a brief description of the claimed defect, including the circumstances under which the defect occurred. Warranty related inquires should be sent to the following address: HOTCHKIS PERFORMANCE, LLC C/O CUSTOMER SERVICE 12035 BURKE ST. SUITE 13 SANTA FE SPRINGS, CA 90670 Hotchkis Performance will not accept product returns without the RGA number, receipt and the information described above. C.O.D. or collect shipments will be refused. Once the returns are received at Hotchkis Performance, we will evaluate the products, verify the sales receipt, and investigate the warranty claim.
[Re: Dan@Hotchkis]
#1839253
06/01/15 10:20 PM
06/01/15 10:20 PM
goldduster318
Lake Orion, MI
I really don't like this. So for most of us there is no warranty. I probably know more about the car than pretty much any licensed mechanic ever will (I actually design car parts).
[Re: Dan@Hotchkis]
#1839320
06/01/15 11:39 PM
06/01/15 11:39 PM
Posts: 22,810 Bitopia
jcc
Bitopia
If you can talk the talk and walk the walk we can usually figure it out pretty quick. If you want us to pay your medical bills and repair your freshly restored car because you installed a leaf spring upside-down; it snapped in half and poked out your eye, it isn't going to happen and we have to cover our butts. Its the sad litigious nature of the world we live in these days. AS you or anyone professional should, because if you don't all takes is one to shut your doors and we have no more parts to buy, nobody wins, As far as the "licensed" requirement, I wonder if there is indeed a license requirement or availability in all 50 sates your products are sold in. I would think dropping licensed and changing the requirement to "experienced" would be a compromise, allow a lot of latitude for interpretation from both sides and be practical.
[Re: AlexP]
#1839643
06/02/15 12:26 PM
06/02/15 12:26 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
ASE Certified technician, or equivalent, would be the better choice of words... unless that's what the legal jargon is attempting to express.
However, there are some ASE Certified technicians that should not be allowed to work on any vehicles based upon their experience.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: AlexP]
#1839900
06/02/15 06:14 PM
06/02/15 06:14 PM
72Swinger
Nebraska
Competent, that should cover it.
[Re: AlexP]
#1840704
06/03/15 06:50 PM
06/03/15 06:50 PM
astjp2
Utah and Alaska
I have a Genuine Federal DOT Mechanics license, but its not good in any state.....
[Re: 72Swinger]
#1841039
06/04/15 12:09 AM
06/04/15 12:09 AM
jcc
Bitopia
Competent, that should cover it. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) , because if there is any sort of problem, its easy to say, that's proof enough the installer was not competent as required.
