Engine Oil
#1834687
05/26/15 05:46 PM
05/26/15 05:46 PM
Posts: 416 Georgia
KingTuna
Georgia
I have tried the search feature, and either it is not working, or am I not smart enough to use it.
I was trying to search to see what oil I need to use in the 440. I know zinc is needed with the flat tappet cams. Do yall run shelf motor oil and use a zinc additive, or go with an oil that comes with high zinc levels?
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
Re: Engine Oil
[Re: KingTuna]
#1834691
05/26/15 05:51 PM
05/26/15 05:51 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use either Shell Rotella or Mobil Delvac 15w40 diesel rated oil.
Re: Engine Oil
[Re: Chris2581]
#1834954
05/27/15 12:05 AM
05/27/15 12:05 AM
Posts: 7,664 IN
ahy
IN
I use either Shell Rotella or Mobil Delvac 15w40 diesel rated oil. Me too. 15W40 Rotella has worked well in a moderately aggressive mech flat tappet application for me.
Re: Engine Oil
[Re: ahy]
#1835029
05/27/15 02:04 AM
05/27/15 02:04 AM
RapidRobert
bradd penn joe gibbs & others. you might read the bobistheoilguy article. plenty of zinc/correct weight/to some extent correct additives for your app (good oil has good additives). just me I prefer non synthetic/frequent changes (synthetic I'm sure is a much better lube but its the suspended metal particles that cause wear in addition to acids etc & an oil change elims that which is the opposite of the synthetic/extended oil ch intervals school. 2cents
Re: Engine Oil
[Re: KingTuna]
#1835054
05/27/15 03:41 AM
05/27/15 03:41 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Use the Google custom search at the very top of each page. Works good. Put in 'oil for 440', and you'll get lots of Moparts hits.
Re: Engine Oil
[Re: shorthorse]
#1835217
05/27/15 01:00 PM
05/27/15 01:00 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I have been using Valvoline VR1 racing oil since my engine was rebuilt.. Easy to find at most Auto parts stores
Re: Engine Oil
[Re: KingTuna]
#1835221
05/27/15 01:07 PM
05/27/15 01:07 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Valvoline VR1 race oil here too. The Rotella and some other diesel oils don't have near the zinc and other additives that they used to. Haven't for some time now...years. Not saying it isn't good oil or that it won't work, just doesn't have what it used to.
Re: Engine Oil
[Re: KingTuna]
#1835335
05/27/15 03:37 PM
05/27/15 03:37 PM
Posts: 416 Georgia
KingTuna
Georgia
Sorry I'm just now getting on to check replies, work has been crazy. I'm thinking about sticking to conventional and adding some zinc additive, or going with the Valvoline VR1 as I have heard good things. I am leary of the synthetic, only because I used it in an older vehicle before and developed a few leaks that I did not have with conventional.
If I used conventional, how much zinc additive would I need to put with each oil change? Half a bottle, a whole?
Re: Engine Oil
[Re: dogdays]
#1835550
05/27/15 09:11 PM
05/27/15 09:11 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
It isn't quite that simple, the zinc is just an easily identifiable component of the molecules that are put into the oil for anti-scuff properties. Right. It's actually the phosphorus that provides the antiwear protection. We tested some oils a while back using neutron activation analysis. Our results can be found here: http://arxiv.org/ftp/arxiv/papers/1502/1502.07261.pdfI've commented on the 540ratblog article in a previous post: The guy seems to know what he's doing. As he points out, a "Mechanical Engineer is clearly the most qualified Engineer to test motor oil" (but evidently not the most qualified engineer to know the difference between proper nouns and regular ol' nouns ). The only problems I have with his data: 1. He doesn't provide any uncertainties anywhere. Seriously, numbers without uncertainties are meaningless. If you don't believe me, I'll sell you my 100,000,000 hp 2002 Ram for $100,000 cash (note: +/- 99,999,775 hp). You never know, it could have 199,999,775 hp and be a good deal... 2. The other problem is this statement: "The ppm (parts per million) quantities of zinc, phosphorus, moly and in some cases titanium, shown in the ranking list below, are taken directly from the Lab Reports that came back from the Professional Lab 'ALS Tribology' in Sparks, Nevada. Some oils have MORE ZINC than phosphorus, while other oils have MORE PHOSPHORUS than zinc. It just depends on the particular oil's formulation. Either way, the numbers below are correct and are NOT typos." The ppm data are mass fractions. Because zinc is ONLY added to oils in the form of ZDDPs (while the phosphorus in oils can be from a variety of molecules) and because ZDDPs always have a 2:1 phosphorus atom to zinc atom ratio, the phosphorus to zinc ppm ratios should never be less than [(30.97*2)/65.39]=0.947. It's pretty basic chemistry. If you take a look at his measurements for "5W30 Joe Gibbs Driven LS30 Performance Motor Oil, synthetic," for example, you can see that the ratio is 1496/1610=0.929. What does this mean? That his data (or the data that he got from ALS Tribology) has some really high uncertainties. That said, there's a lot more to a good motor oil than ZDDP-content. The best way to measure the quality of a motor oil is through mechanical tests, which is exactly what the guy who wrote the 540 Rat blog article does.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Engine Oil
[Re: dogdays]
#1835586
05/27/15 10:22 PM
05/27/15 10:22 PM
RapidRobert
There's a dozen other sacred cows out there in the blogosphere, all of them deserving to be butchered. But oil, like filters and a few other things, have become a religion to the true believers. And they go on jihad against the infidels who dare to suggest that their ideas of the Oil God could possibly be wrong. Ignorance will shout down the truth every time. Bah! R. Hey Dog ya got any left
Re: Engine Oil
[Re: dogdays]
#1835757
05/28/15 02:00 AM
05/28/15 02:00 AM
kentj340
Cut and Shoot, TX
We filter oil out of the container into the application because oil sampling will show that the (new) oil isn't as clean as is necessary.
Bah!
R. Yeah, I've seen that. Next time you pour out new oil, inspect what's left in the bottom of the container...
