73 charger disc spindles #1834588
05/26/15 03:21 PM
05/26/15 03:21 PM
USA
b54406barrel Offline OP
USA
Will these these work to convert 62-65 b-body? Thanks.
http://portland.craigslist.org/wsc/pts/4992997100.html
Re: 73 charger disc spindles [Re: b54406barrel] #1834593
05/26/15 03:27 PM
05/26/15 03:27 PM
AndyF Offline
AndyF  Offline
Yes they will work but that is a lot of extra metal to buy. FMJ knuckles usually aren't too hard to find in wrecking yards around Portland.
Re: 73 charger disc spindles [Re: AndyF] #1834595
05/26/15 03:29 PM
05/26/15 03:29 PM
USA
USA
Thank you! up
F is a volare, isn't it? What are M & J's? Thank you.
Re: 73 charger disc spindles [Re: b54406barrel] #1834599
05/26/15 03:37 PM
05/26/15 03:37 PM
AndyF Offline
AndyF  Offline
Any rear drive with a bent bar front end will work. There are a bunch of nameplates but they all kind of look the same. If you're in the Portland area I have a set of new reproduction disc brake knuckles that I don't need. So that is another way to go.
Re: 73 charger disc spindles [Re: AndyF] #1834614
05/26/15 03:59 PM
05/26/15 03:59 PM
USA
USA
Thank you. I'd like to pick up as much 'stuff' as needed/useable in one shot. The charger front end would have a sway bar too, so I was going to see about width and welding tabs on the lower arm.
Thank you much for you help! up
Re: 73 charger disc spindles [Re: b54406barrel] #1834642
05/26/15 04:47 PM
05/26/15 04:47 PM
AndyF Offline
AndyF  Offline
If you're working on an early B-body then you'll most likely want to use a 68-69 style of anti-sway bar. Those will weld on without too much trouble.
I have an original early B-body anti-sway bar if you're interested but I'm not sure if you can buy bushings for them anymore. I also have a couple of the 68-69 style bars on hand.
You'll need to hang the calipers to the rear if you use the 68-69 style of bar.
