68 A body dash wiring help #1834167
05/25/15 09:44 PM
05/25/15 09:44 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
when i...
use left turn, the green dash light comes on and flashes
use flashers, both green dash lights flash
use right turn, dash light does nothing
why?
Re: 68 A body dash wiring help [Re: mcat4321] #1834194
05/25/15 10:22 PM
05/25/15 10:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
bad contact on the turn signal switch/cam. does the actual turn signal work on both front and back corners? if not then it could also be a faulty ground.
Re: 68 A body dash wiring help [Re: mikemee1331] #1834319
05/26/15 01:57 AM
05/26/15 01:57 AM
What Mike said, Right TS's work normally with stalk up? (only dash indicator bulb is out?). does dash bulb work when flashers are engaged? and all 4 corners work with flashers engaged? everything works good ex the R dash bulb when using the stalk?
