MSD 6al to Digital 6 Plus
#1834163
05/25/15 09:40 PM
05/25/15 09:40 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
Any benefit to switching? Is anyone running a Digital 6? I like the idea of having the 3 step already in the box. Running a 6al now. Thanks.
Better get inside Ma. Looks like a storm's comin'.
Re: MSD 6al to Digital 6 Plus
[Re: Dartthunder340]
#1834421
05/26/15 11:20 AM
05/26/15 11:20 AM
Posts: 13,405 Marion, South Carolina [><]
an8sec70cuda
Several years ago I "upgraded" to the Digital 6 plus and had a high rpm misfire that wouldn't go away. Rerouted wires b/c all we figured it could be was interference, made no difference. Put my old 6AL back in and it runs perfect. Sent the Digital 6 back to MSD, exchanged for a new one, talked it over w/ their tech guy...same result. Back w/ the old 6AL and all was good.
Had the same issue on a Mustang after I installed an MSD digital multistep retard for the nitrous. Was still using a 6AL along w/ it...developed a high rpm misfire. Swapped the digital retard box for the old style 3 stage retard box that uses chips...problem went away.
I know a lot use them and have no trouble, but that has not been my experience.
edit...both times I had issues, the boxes were mounted inside the car under the dash.
#1835083
05/27/15 08:16 AM
05/27/15 08:16 AM
Posts: 1,629 pa
572charger
pa
i have had a digital 6 in my car since 2003 with NO problems those msd boxes just like all other efi computers ect.. have to be grounded to the battery !!!!not to the fire wall or frame !!!!!!!! just my 2 cents
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
