What tire? #1833997
05/25/15 04:54 PM
05/25/15 04:54 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Thinking of throwing a set of stickies on the duster to see what it will do. Would prefer a 27" tall tire around 8" wide. Also would prefer a 14" rim, but i can use a 15". I saw a couple of M&H muscle car d.o.t.'s in 15" i think would work, but i was hoping to find 14" so i could use the stock wheels.
Are the musclecar d.o.t.'s any good? I can only stall the car to around 1500 with the converter in it, but even with 200+lbs in the trunk for ballast the car won't even think to hook with the polyglass. I want something that will hook, period. If i can get that in a dot, even better.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: What tire? [Re: F1Scamp] #1834004
05/25/15 05:14 PM
05/25/15 05:14 PM
Locomotion Offline
Locomotion  Offline
Hoosier has a wide variety of applications that you can do some research on. I only run their drag slicks but have seen positive discussions about their other tires as well.
Hoosier tire options
Re: What tire? [Re: F1Scamp] #1835478
05/27/15 07:21 PM
05/27/15 07:21 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Hoosier Quick Time Pro's.
Re: What tire? [Re: F1Scamp] #1835485
05/27/15 07:31 PM
05/27/15 07:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just curious what you 60 ft now as I dont know if you will pick up alot. 10.70's at 125 is not to bad but I guess you could get down to 10.50's at that mph as I am sure your car has great weight transfer. My self I like the Hoosier radial 30 x 9 slicks I use. Ron
Re: What tire? [Re: F1Scamp] #1835568
05/27/15 09:45 PM
05/27/15 09:45 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Best 60' is a 1.540 with the polyglass leaving just off idle (around 1000rpm). I dont know how much more it has in it, but i dont see why it wouldnt go in the mid-low 1.4's. I dont want too tall of a tire as the gearing is near perfect now. Alittle taller than the g70-14's would be perfect.
Re: What tire? [Re: F1Scamp] #1835650
05/27/15 11:46 PM
05/27/15 11:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
26x9.50x14 is tallest Hoosier in a 14" wheel.
Mopar to the bone!!!
Re: What tire? [Re: F1Scamp] #1835651
05/27/15 11:48 PM
05/27/15 11:48 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
hoosier quick time is available in a 275/55/14, 26" tall 8.5 tread, 10.1" section width, looks like everythiing else is alot wider. seems like pro trac made a 14 but i dont see it in the jegs catalog
