main hoop and strut to frame conn #1833678
05/25/15 03:23 AM
05/25/15 03:23 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
Heys guys is it legal to run short strut from main hoop to top of frame connector? Here's pic it just setting there now haven't welded yet. Thanks Bradley
Re: main hoop and strut to frame conn [Re: roadrunnerreds] #1833721
05/25/15 10:25 AM
05/25/15 10:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm not sure if your asking if outriggers between the subframe and the rocker are legal to land the main hoop? The answer is yes. The angled short bar in your picture is referred to as the"D" bar. It should attach at the intersection of the main hoop and the shoulder bar. It's intention is to prevent the main hoop from moving left or right on impact. I also like to plate the inside of the rocker with thicker material to spread the load. My cage is certed to 8.50.
Doug
Re: main hoop and strut to frame conn [Re: roadrunnerreds] #1833777
05/25/15 12:03 PM
05/25/15 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What your trying to do is the right idea.. BUT we
normally drop that tube from the main hoop cross
bar then angle over to the frame connector.. remember
that magic word.. triangulation .. also... use the hole
saw to cut that joint... it'll be a pretty long cut but
it'll come out nice(cut the extra material out of the
ID of the hole saw)
EDIT
You can see it on the right
wave
Re: main hoop and strut to frame conn [Re: roadrunnerreds] #1833895
05/25/15 02:42 PM
05/25/15 02:42 PM
Gettysburg Pa
Gettysburg Pa
Mr PBody I see on that chassis it is not cut that long it is more on crossover bar seat belt bar. Do you have to have this bar? Thanks Bradley
Re: main hoop and strut to frame conn [Re: roadrunnerreds] #1833901
05/25/15 02:46 PM
05/25/15 02:46 PM
Gettysburg Pa
Gettysburg Pa
The main hoop actually goes through box tubing from frame connector to rocker will.
Re: main hoop and strut to frame conn [Re: roadrunnerreds] #1833921
05/25/15 03:16 PM
05/25/15 03:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No the cut isnt that long due to it being cut on
the horizontal and not the vertical.. If your talking
the cross bar yes it suppose to be there.. 3" below the
shoulder is the spec(if I recall correctly)
wave
