Lower Control Arm/Front Strut Rod Bushings - Info Wanted
#1833497
05/24/15 10:34 PM
05/24/15 10:34 PM
Posts: 1,565 Macomb, MI
vinnyd76
Macomb, MI
Does anyone remanufacturer the lower control arm / front strut rod bushings like the original as shown in the attached pic from a 1970 Duster? I recently purchased a set from Moog (K7040) and the bushings were not the same shape as the original, so I believe there is a potential for ground out because the shape is not the same.
Re: Lower Control Arm/Front Strut Rod Bushings - Info Wanted
[Re: vinnyd76]
#1833732
05/25/15 10:48 AM
05/25/15 10:48 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
on a 1974 satellite, it matter which month the car was made in. There are 2 different styles.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
