Re: E body door hinges
[Re: RROD]
#1833261
05/24/15 03:01 PM
05/24/15 03:01 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Was mentioned on here a really long time ago, but a grease zerk can be added as well. Would anyone happen to have a pic of how/where to put it?
Mo' Farts
Moderated by "tbagger".
[Re: RROD]
#1833264
05/24/15 03:04 PM
05/24/15 03:04 PM
Posts: 4,924 new berlin wisconsin
Mr T2U
if you can leave your car door open wile you repair the hinges buy the pins and bushings. if there might be problems with leaving your door open during the repair down time buy rebuilt hinges. best of both worlds buy hinge cores, rebuild, replace then sell your old hinges when done.
perception is 90% of reality
[Re: Car Nut]
#1833495
05/24/15 10:30 PM
05/24/15 10:30 PM
Posts: 4,761 Florida
BDW
YearOne has rebuilt door hinge sets on clearance, no core. With 30% off going on now, you can get a set for less than $90. They were like $300 with the core charge. You can keep your set for future use. That does sound like a pretty good deal. Wonder who does the rebuild? Anyone actually have a set that can attest to quality?
[Re: Grizzly]
#1833813
05/25/15 01:00 PM
05/25/15 01:00 PM
Posts: 1,567 Ky
jt4406
Ky
I added them to my car, top hinge was easy, just drill and tap a hole, the bottom hinge required a steel sleeve between the top and bottom bushing, drilled the hole in the sleeve, here's a couple pics. Jess
Yeah, it's hopped up to over 160...
