Magnum 500 Backspace #1832818
05/23/15 02:23 PM
05/23/15 02:23 PM
Alberta Canada
PossessedDuster Offline OP
Alberta Canada
What backspace is best for a 67' B-body?
My current cop car wheels are 15x7 with a 4.5" back space and 255/60/15 tires clear the quarter panel by 1" and the leaf by 1 1/4"
The repro magnums "stock" sizes are 4 1/4 back space. Should this be ok?
Re: Magnum 500 Backspace [Re: PossessedDuster] #1832873
05/23/15 05:02 PM
05/23/15 05:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Original cop car wheels are 4.25" backspace.
Are you measuring from the edge of the lip or the outside bead?
Re: Magnum 500 Backspace [Re: PossessedDuster] #1832893
05/23/15 06:02 PM
05/23/15 06:02 PM
Alberta Canada
Alberta Canada
I measured from the edge of the lip.
I take it this was the wrong way to measure?
Re: Magnum 500 Backspace [Re: PossessedDuster] #1832903
05/23/15 06:23 PM
05/23/15 06:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you measure form the outside of the bead you'll get 4 1/4" or extremely close. You'll get the same measurement off a set of original 15x7 Rallye or 15x7 steel rims.
So the repro Magnums that are listed as 4 1/4" should have the same backspace as you current 15x7 Cop rims.
