I have downloaded and printed the '72 A-body (Dart or Valiant) wiring diagram found in many places online, and it has a significant drawing error.
The Start line from the ignition switch is shown as running to bulkhead connector pin L... which in the engine compartment is connected to the horn! Likewise, the horn relay line is shown running to pin T, which is the line to the starter relay. Both are dark green with a red stripe, which is probably what led to the drafting mistake.
If your A-body were really wired this way it'd be nearly theftproof - push the horn button to start the car, turn the key to blow the horn
Anyone sufficiently versed in reading schematics would probably notice this and not attempt to wire it that way! But just in case, I thought I'd share...
