Saginaw pump pulley not aligning with crank. Can I adjust?
#1831104
05/20/15 09:57 PM
05/20/15 09:57 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I took the saginaw pump from a 1975 318 to put on my 440. I bought power steering brackets from 440 source. I mocked up the front of the engine, and my ps pulley is way out of alignment with the crank pulley. It sits about 3/4" further back than the crank pulley. My first thought was to take the pulley off and shim it, but after I got the first nut of the shaft, I could not get the pulley off, it must be a press fit. What are my options? Is there a puller tool I can use to pull the pulley off, then place a shim behind it, then reinstall? Or do the small block pumps have different pulleys than the big block pumps? If thats the case would it be easier to just buy a new pump/pulley for a big block?
Re: Saginaw pump pulley not aligning with crank. Can I adjust?
[Re: Adam71Charger]
#1831299
05/21/15 04:22 AM
05/21/15 04:22 AM
Posts: 566 WA
tman
WA
[Re: Adam71Charger]
#1833622
05/25/15 01:14 AM
05/25/15 01:14 AM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
The shaft play is normal. The cans and the later pumps had a pressed on pulley vs the keyed shaft with nut are the major differences in the pumps.
The only Carbs I care about are under the hood!
