2003 Liberty ?s #1831161
05/20/15 11:05 PM
05/20/15 11:05 PM
North of the Motor City
DartGTDan Offline OP
My son has a 2003 Liberty (3.7L, Auto., A/C) with 75,000 miles. Driving home today the battery and engine lamps illuminated. The battery was replaced last spring. The battery and alternator terminals are clean and tight. Everything is original. Bad alternator? Other things to check out?
Re: 2003 Liberty ?s [Re: DartGTDan] #1831307
05/21/15 08:21 AM
05/21/15 08:21 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Test the alternator... Probably bad..
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 2003 Liberty ?s [Re: DartGTDan] #1831370
05/21/15 11:51 AM
05/21/15 11:51 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Here's a pretty simple check. Grab a voltmeter, get the static state of charge. Then start the car, if the voltage stays exactly the same its usually the alt.
Re: 2003 Liberty ?s [Re: moparjim79] #1831756
05/21/15 10:08 PM
05/21/15 10:08 PM
Took the alternator in for bench test and it PASSED. Re-installed and everything is good now. W T H
Re: 2003 Liberty ?s [Re: DartGTDan] #1832067
05/22/15 11:45 AM
05/22/15 11:45 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Brushes may have been stuck (worn down) and in the process of r&r they were jarred loose.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
