Re: Goodmark Quarter panel Quality (70 Challenger)
[Re: RROD]
#1830348
05/19/15 09:45 PM
05/19/15 09:45 PM
Posts: 547 Minnesota
RROD
Minnesota
[Re: RROD]
#1830530
05/20/15 01:15 AM
05/20/15 01:15 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I used them back before amd and they were nice panels. They needed tweaked and so on, but so do amd quarters. I have did body work on amd and goodmark panels and there wasn't much difference in how straight they were from my experience. I do body/paint pretty much daily.
One day I need to post all the issues I've had with amd parts... from terrible fitting deck filler panels, to b-body cowl panels that aren't the same dimensions as the factory cowl.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1830646
05/20/15 10:25 AM
05/20/15 10:25 AM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
If they are like the 67 cuda 1/4's then stay away from them! I have a set in my shop cause the 67 I am doing for a customer only needed very small patches on lower sections and couldn't force myself to cut up a set of OEm fastback style ones from AMD even at my dealer cost! I chose to get these Goodmark ones. If I was to have to put the full skin ones on I would stand a better chance of taking a flat stock sheet or metal and hammer and dolly a set out. Be just about as good! Ahead of the wheel house there is suppose to be a body line on lower area. Its not even half of what it should be. The gas door recessed area isn't even as defined as original. IMO i would run away from anything that is Goodmark after seeing these POS!! But that is just my .02
corey
Contact Me about AMD Prices
[Re: RROD]
#1830791
05/20/15 02:06 PM
05/20/15 02:06 PM
Silver70
Rust Belt, SW PA
Heres a 69 rr goodmark panel I just got delivered today I ordered from rockauto... No waves
[Re: RROD]
#1831380
05/21/15 12:09 PM
05/21/15 12:09 PM
Silver70
Rust Belt, SW PA
And why not... installed and fit like a glove. Car has original everything else less the quarters and fit perfect up to the original wheel house, extension, etc... Certainly not perfect, but I'm more than happy with it.
[Re: Silver70]
#1831503
05/21/15 03:32 PM
05/21/15 03:32 PM
hotairballoonpilot
South Dakota
Agree those 2 look good. I have not figured out how to do pics but I have some of these 67 cuda skins.
[Re: Silver70]
#1841521
06/04/15 04:22 PM
06/04/15 04:22 PM
hotairballoonpilot
South Dakota
Here should be the Goodmark qrts for the 67 cuda I am doing. Can see they are actually longer than the original qrts. Got them to fit but took alot of reshaping to use just the lower section. The other pic should be what little of the body line is in the front area of the skin. Far less than the original. Just my .02 from what i have seen on these qrts compared to the AMD I have used.
[Re: TJP]
#1851104
06/17/15 03:07 PM
06/17/15 03:07 PM
Posts: 1,030 NJ
EV2RTSE
NJ
From what I'm reading here the quality seems to vary by model of car - evidently some are better than others. This was just after the Goodmark full Challenger quarters came out, quite a few years ago now. We were very pleased with the fit overall- http://www.moparts.org/Tech/Archive/paint/8.html
[Re: conteycp]
#1851212
06/17/15 05:43 PM
06/17/15 05:43 PM
Silver70
Rust Belt, SW PA
I know from reading these posts that everyone has good things to say about AMD but let me tell you it is not all wine and roses . I had used several AMD panels and fenders and hoods in the last 5 years and I have felt there stamping quality and dimensions to be horrible. We just installed a hood on a 68 Roadrunner, this hood cost 700 plus with shipping. The car it was going on was a untouched and straight piece so it should have bolted straight on with little to no massaging . We had to cut the understructure on the right front corner to get it to follow the fender line . The hood inserts were not stamped deep enough and so this brand new hood ended up taking 15 hours of shop time to make it right. I realize that before AMD came around there was little to no hope of restoring some of these cars and I am sure not every piece they make is as bad as this hood was but I think they should do more quality control for each type of part before moving on to the next. I used an AMD hood on a 69 gtx and it was one of the best repop parts I ever used. I didn't have any of these issues. I was very impressed with it and took very little work before paint.
[Re: RROD]
#1851585
06/18/15 02:26 AM
06/18/15 02:26 AM
Posts: 1,396 chicago,il
jaque
chicago,il
no complaints either goodmark worked great, i didnt do the work but i remeber the guy that did the work was rather suprised at the fit and alignment..
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
