Re: 1.6 CRANE ROLLER ROCKERS VS 1.5 HS's
[Re: MIKES_DUSTER]
#1829543
05/18/15 10:04 PM
05/18/15 10:04 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
[Re: MIKES_DUSTER]
#1829552
05/18/15 10:16 PM
05/18/15 10:16 PM
Posts: 561 USA
B3RE
USA
Heres my dilemma. Im using the 1.6 Cranes due to me running a SB with stock heads and poor rocker geometry and to get a little more lift on my cam. I had a adjuster break and heres my question.....Just buy a new adjuster or switch over to the 1.5 HS rockers????
Thanks!!!!! I'll agree that you have poor geometry, and the Harlands will make it worse. You likely broke the adjuster because the valvetrain is getting pounded. Keep the Cranes, get the geometry fixed, and you shouldn't be breaking any more adjusters.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: Cab_Burge]
#1829663
05/18/15 11:13 PM
05/18/15 11:13 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
That's good advice, as is Br3,s. If the one adjuster broke the others aren't far behind because of the same geometry problems. Too short of pushrods, IMO, or ETC.
[Re: MIKES_DUSTER]
#1830063
05/19/15 02:38 PM
05/19/15 02:38 PM
Posts: 561 USA
B3RE
USA
OK....The Cranes are BRAND NEW along with my motor. Only had some start up times and maybe a few miles on it and it did not break on start up. Rick (AARLUCAS)set them up for me after buying BRAND NEW Manton pushrods. We also put lash caps on because we didn't like the way the rollers sit on the valve. Rick is in NOOOOOOOO WAY at fault with what happened, he has been AWESOME!!!!!!!
How much are good adjusters??? Should I get them thru Crane???
Thanks again for the help!!!!! "We also put lash caps on because we didn't like the way the rollers sit on the valve." Oh boy, here we go again. How many WOT runs did you make, and how high did you twist it? If you haven't done so, please read the tech articles on my website. I see way too many Mopar valvetrain issues, and it doesn't need to be.
Mike Beachel
[Re: MIKES_DUSTER]
#1830088
05/19/15 03:13 PM
05/19/15 03:13 PM
Posts: 4,457 Washington
madscientist
Washington
A lash cap is a piss poor way to correct geometry. You have to RAISE and MOVE the shaft towards the intake manifoild if the valves are too long, or LOWER and MOVE the shafts closer to the springs if the valves are too short.
Take the lash capss off, correct the geometry and be done with it.
[Re: lewtot184]
#1830293
05/19/15 08:29 PM
05/19/15 08:29 PM
Posts: 561 USA
B3RE
USA
nobody ever looks at push rod/rocker adjuster geometry. everybody is stuck in the old "2-3 threads" showing b.s. Nobody? Everybody?
Mike Beachel
[Re: B3RE]
#1830301
05/19/15 08:41 PM
05/19/15 08:41 PM
Posts: 3,916 usa
lewtot184
usa
nobody ever looks at push rod/rocker adjuster geometry. everybody is stuck in the old "2-3 threads" showing b.s. Nobody? Everybody? yes.
[Re: lewtot184]
#1830314
05/19/15 08:54 PM
05/19/15 08:54 PM
Posts: 561 USA
B3RE
USA
nobody ever looks at push rod/rocker adjuster geometry. everybody is stuck in the old "2-3 threads" showing b.s. Nobody? Everybody? yes. Ok, lol. I am well aware of the effects of pushrod geometry. The question is, are the Mopar rocker manufacturers? I have yet to see one that has the proper design on the adjuster side of the rocker. And, before anyone trots out their favorite brand, that includes every "single shaft" system from ProForm, to T&D. Pushrod length plays a part, but the rest is in the rocker design. They're a bit difficult to change.
Mike Beachel
[Re: Pstew]
#1830853
05/20/15 03:32 PM
05/20/15 03:32 PM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
another vote for Smith Bros.
Yes I live in Michigan, so there is still 1 light on
