Page 2 of 3 1 2 3
Re: Time for a 727?? [Re: mshred] #1828973
05/18/15 04:04 AM
05/18/15 04:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....or is there a "preferred" planetary gear set for the 904? I'm not sure...
Re: Time for a 727?? [Re: mshred] #1828978
05/18/15 04:45 AM
05/18/15 04:45 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
The 904 in my 62 Valiant is on the ground right now. Unfortunately I'm married to it, the tunnel is so small in these cars, I had to cut it just to get the carbon shield on there. I'll just keep throwing better parts at it, I suppose. Got the good input shaft this go around.
001 (3).JPG (470 downloads)
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Time for a 727?? [Re: mshred] #1829013
05/18/15 09:55 AM
05/18/15 09:55 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
A 727 won't cost much to run at that hp. I run the STK clutches in mine. What's the et?
Re: Time for a 727?? [Re: mshred] #1829016
05/18/15 10:31 AM
05/18/15 10:31 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
mshred who is building your transmission in the Toronto or even Ontario or are you building the transmission yourself.
Re: Time for a 727?? [Re: 72chrgrally] #1829081
05/18/15 12:26 PM
05/18/15 12:26 PM
K
KOS Offline
KOS  Offline
K
Originally Posted By 72chrgrally
Member KOS has a killer sb 727 for sale. He's in Hamilton.
thx for the plug Steve but the trans is not forsale unless the motor sells first......i have a couple guys interested in the complete pkg.btw 727 i remember talking to you about this before you did the 904 dont waste anymore $$$.i also have a couple cores and lots parts if your in need.
Re: Time for a 727?? [Re: mshred] #1829347
05/18/15 05:47 PM
05/18/15 05:47 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Yanked the trans and pulled it apart...I sheared the output shaft clean off where it engages in the front planetary. I have 2 spare 904's that I paid $50 for just for parts, so I am going to grab an output from one of those and throw it in.
Not sure what I am going to do though...I only sprayed a small hit through this thing last year, and wanted to turn it up this year, and this is the result already...Starting to think I may just throw the low gearset back in, order up a motor converter and run it like that this year until I can swing the funds to do what I would like to have it hold up. Last I checked aftermarket output shafts are out of stock everywhere, so upgrading wouldn't be an option
I have heard before that a looser converter or more gear will help these live longer...which is what I need at my weight with this thing....Still haven't decided 100% if this is what I will do since I really wanted to pour the coals to this thing with the bottle this year, but at this point it makes the most sense financially and lets me still get out and have fun racing the car
Re: Time for a 727?? [Re: hemicar1971] #1829348
05/18/15 05:48 PM
05/18/15 05:48 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Parts and advice from Hutch, build it myself
Re: Time for a 727?? [Re: mshred] #1829467
05/18/15 08:32 PM
05/18/15 08:32 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
While I like the glide I have broken to sets of plantaries and one input shaft. I now have a ATI 1.80 and a turbo shaft 😉
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Time for a 727?? [Re: mshred] #1829655
05/18/15 11:09 PM
05/18/15 11:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Patch it up and hit it right between the eyes! thumbs
me on the other hand.... don't think I'm ready for the PG route. going to spend money on the 727 and go from there.
Re: Time for a 727?? [Re: mshred] #1829681
05/18/15 11:28 PM
05/18/15 11:28 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mshred, Your message box is full.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Time for a 727?? [Re: J_BODY] #1829691
05/18/15 11:36 PM
05/18/15 11:36 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Wont lite, I am scared to spray it now LOL...Ill have to decide what to do asap since I want to get this thing back together and running this week
Re: Time for a 727?? [Re: D-50] #1829692
05/18/15 11:36 PM
05/18/15 11:36 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for the heads up! Gonna clear it now
Re: Time for a 727?? [Re: mshred] #1829709
05/18/15 11:48 PM
05/18/15 11:48 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've always been lucky enough to have 2 different local guys that do 727's on the cheap, I've raced my whole life and never spent more than $350 to drop off a stock 727 and pick it up race ready, basically just a bolt-in sprag and a decent rebuild kit. 2 of the cars ran 9's for years, never a problem. But I never did hit them with a transbrake or power adder.
Powerglides seem to be the way to go these days but I personnaly think a 3 speed is more fun and sounds better going down the track.
Re: Time for a 727?? [Re: mshred] #1830151
05/19/15 04:18 PM
05/19/15 04:18 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted By mshred
I'll have to decide what to do asap since I want to get this thing back together and running this week
Since you have a spare output shaft, put it back together and race a few weeks/months while you plan your next step.
I would be surprised if you have the exact same breakage anytime soon. It might not last 300 passes, or something else might give up... But at least you are racing right away.
Re: Time for a 727?? [Re: 440Jim] #1830158
05/19/15 04:25 PM
05/19/15 04:25 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Did some thinking and talking with a few board members, and with what I wanted to do with the car, I am going to just replace the shaft and try it again. I'll stick a smaller jet in the plate and cross my fingers that it lasts the rest of the season on a new shaft. It just sucks when racing season is only a few months because of the weather and you break and have to sit out to fix things, that is what I want to avoid, but breakage comes with the territory.
Should hopefully have this thing all back together by the weekend
Re: Time for a 727?? [Re: mshred] #1830162
05/19/15 04:28 PM
05/19/15 04:28 PM
NC
440Jim Offline
440Jim  Offline
NC
Just curious, do you have any upgrade to the front clutch spring? I think there is a better single spring, and a complete multi-spring upgrade.
Re: Time for a 727?? [Re: 440Jim] #1830260
05/19/15 07:47 PM
05/19/15 07:47 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I have the multi spring upgrade, yes
Re: Time for a 727?? [Re: mshred] #1830271
05/19/15 07:59 PM
05/19/15 07:59 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I have a real nice CRT 727 that I will be selling if and when Matt gets his switched over to a powerglide. I got it with my black Duster when I bought it and Matt is KINDA borrowing it. 3 nice convertors too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Time for a 727?? [Re: pittsburghracer] #1830285
05/19/15 08:20 PM
05/19/15 08:20 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Let me know when John and depending on whats going on (financially) and what direction I go with this thing I may be interested
Re: Time for a 727?? [Re: 440Jim] #1830583
05/20/15 02:06 AM
05/20/15 02:06 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I wouldn't.........he runs on drag radials. That is the MOST unforgiving tire there is for a race car. Would be better off with slicks from a driveline breakage aspect.
As for the nitrous, you can likely spray it all you want, just don't leave on it, because you are going to break it again nitrous or not
Monte
Page 2 of 3 1 2 3
