Best valley pan/gasket combo for intake changeouts?
#1828523
05/17/15 02:43 PM
05/17/15 02:43 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
On my 440 Im starting with aluminum eddy rpm heads and aluminum rpm intake. I want to try some single plane manifolds later. Since I know I'll most likely be switching out the intake, multiple times possibly, whats the best way to efficiently seal the valley but not create a lot of work for myself when it comes time to swap intakes?
Right now I have the felpro valley pan with 4 gaskets, uninstalled. I dont want to use any hardening RTV, but I despise vacuum and oil leaks, am I asking for trouble installing the gaskets dry? I have hylomar, but I've found it not so great to clean up. Whats my options here? I'm willing to purchase a different vally pan if it suits my needs better.
Re: Best valley pan/gasket combo for intake changeouts?
[Re: Adam71Charger]
#1828532
05/17/15 02:56 PM
05/17/15 02:56 PM
RapidRobert
#1 you want the heads and or intake milled & the right thickness of paper gaskets (if you use em & I do), those three things so that the ports and therefore the bolt holes are aligned & that those surfaces are checked/milled flat. I'm assuming you are good there. Ma used no paper so you can get by without em & many do. If I was to do alot of intake switching (I cant see that myself) I would usem (paper) dry then new paper ones with each change
[Re: Adam71Charger]
#1828536
05/17/15 03:05 PM
05/17/15 03:05 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
[Re: Adam71Charger]
#1828646
05/17/15 05:42 PM
05/17/15 05:42 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
What's wrong with just using the original type valley pan? If you think your going to get a better seal using gaskets on each side you'll be wrong. By stacking gaskets [ one one each side of the valley pan gasket ] you'll never even get the intake bolts in. The only reason to use multiple gaskets is when your heads and block have been milled a lot. You can reuse your stock type valley pan gasket multiple times by using a gasket sealer like spray on copper coat and a dab of blue silicone sealant in each corner.
[Re: rowin4]
#1829307
05/18/15 04:43 PM
05/18/15 04:43 PM
Adam71Charger
What's wrong with just using the original type valley pan? If you think your going to get a better seal using gaskets on each side you'll be wrong. By stacking gaskets [ one one each side of the valley pan gasket ] you'll never even get the intake bolts in. The only reason to use multiple gaskets is when your heads and block have been milled a lot. You can reuse your stock type valley pan gasket multiple times by using a gasket sealer like spray on copper coat and a dab of blue silicone sealant in each corner. There's nothing wrong with it, I've just read posts from guys here that said the stock bath tub pan is meant for iran heads with iron intake, and that there is problems when using aftermarket aluminum heads or intake or both
[Re: Kern Dog]
#1829310
05/18/15 04:46 PM
05/18/15 04:46 PM
Adam71Charger
You can cement the gaskets to both sides of the valley pan, THEN spray PAM cooking spray on the gaskets to keep them from sticking. If I tried this method Would vasoline work too? or even some thick assembly lube?
