Re: Time for a 727??
[Re: mshred]
#1828978
05/18/15 04:45 AM
05/18/15 04:45 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The 904 in my 62 Valiant is on the ground right now. Unfortunately I'm married to it, the tunnel is so small in these cars, I had to cut it just to get the carbon shield on there. I'll just keep throwing better parts at it, I suppose. Got the good input shaft this go around.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: 72chrgrally]
#1829081
05/18/15 12:26 PM
05/18/15 12:26 PM
KOS
Member KOS has a killer sb 727 for sale. He's in Hamilton. thx for the plug Steve but the trans is not forsale unless the motor sells first......i have a couple guys interested in the complete pkg.btw 727 i remember talking to you about this before you did the 904 dont waste anymore $$$.i also have a couple cores and lots parts if your in need.
[Re: hemicar1971]
#1829348
05/18/15 05:48 PM
05/18/15 05:48 PM
Posts: 3,415 Toronto
mshred
Toronto
mshred who is building your transmission in the Toronto or even Ontario or are you building the transmission yourself. Parts and advice from Hutch, build it myself
[Re: mshred]
#1829467
05/18/15 08:32 PM
05/18/15 08:32 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
While I like the glide I have broken to sets of plantaries and one input shaft. I now have a ATI 1.80 and a turbo shaft 😉
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: mshred]
#1829681
05/18/15 11:28 PM
05/18/15 11:28 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mshred, Your message box is full.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: J_BODY]
#1829691
05/18/15 11:36 PM
05/18/15 11:36 PM
mshred
Toronto
Patch it up and hit it right between the eyes! me on the other hand.... don't think I'm ready for the PG route. going to spend money on the 727 and go from there. Wont lite, I am scared to spray it now LOL...Ill have to decide what to do asap since I want to get this thing back together and running this week
[Re: D-50]
#1829692
05/18/15 11:36 PM
05/18/15 11:36 PM
mshred
Toronto
Mshred, Your message box is full. Thanks for the heads up! Gonna clear it now
[Re: mshred]
#1829709
05/18/15 11:48 PM
05/18/15 11:48 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I've always been lucky enough to have 2 different local guys that do 727's on the cheap, I've raced my whole life and never spent more than $350 to drop off a stock 727 and pick it up race ready, basically just a bolt-in sprag and a decent rebuild kit. 2 of the cars ran 9's for years, never a problem. But I never did hit them with a transbrake or power adder. Powerglides seem to be the way to go these days but I personnaly think a 3 speed is more fun and sounds better going down the track.
[Re: mshred]
#1830151
05/19/15 04:18 PM
05/19/15 04:18 PM
Posts: 16,928 NC
440Jim
NC
I'll have to decide what to do asap since I want to get this thing back together and running this week Since you have a spare output shaft, put it back together and race a few weeks/months while you plan your next step. I would be surprised if you have the exact same breakage anytime soon. It might not last 300 passes, or something else might give up... But at least you are racing right away.
[Re: 440Jim]
#1830158
05/19/15 04:25 PM
05/19/15 04:25 PM
mshred
Toronto
I'll have to decide what to do asap since I want to get this thing back together and running this week Since you have a spare output shaft, put it back together and race a few weeks/months while you plan your next step. I would be surprised if you have the exact same breakage anytime soon. It might not last 300 passes, or something else might give up... But at least you are racing right away. Did some thinking and talking with a few board members, and with what I wanted to do with the car, I am going to just replace the shaft and try it again. I'll stick a smaller jet in the plate and cross my fingers that it lasts the rest of the season on a new shaft. It just sucks when racing season is only a few months because of the weather and you break and have to sit out to fix things, that is what I want to avoid, but breakage comes with the territory. Should hopefully have this thing all back together by the weekend
[Re: 440Jim]
#1830260
05/19/15 07:47 PM
05/19/15 07:47 PM
mshred
Toronto
Just curious, do you have any upgrade to the front clutch spring? I think there is a better single spring, and a complete multi-spring upgrade. I have the multi spring upgrade, yes
[Re: mshred]
#1830271
05/19/15 07:59 PM
05/19/15 07:59 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a real nice CRT 727 that I will be selling if and when Matt gets his switched over to a powerglide. I got it with my black Duster when I bought it and Matt is KINDA borrowing it. 3 nice convertors too.
[Re: pittsburghracer]
#1830285
05/19/15 08:20 PM
05/19/15 08:20 PM
mshred
Toronto
I have a real nice CRT 727 that I will be selling if and when Matt gets his switched over to a powerglide. I got it with my black Duster when I bought it and Matt is KINDA borrowing it. 3 nice convertors too. Let me know when John and depending on whats going on (financially) and what direction I go with this thing I may be interested
[Re: 440Jim]
#1830583
05/20/15 02:06 AM
05/20/15 02:06 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I'll have to decide what to do asap since I want to get this thing back together and running this week I would be surprised if you have the exact same breakage anytime soon. It might not last 300 passes, or something else might give up... But at least you are racing right away. I wouldn't.........he runs on drag radials. That is the MOST unforgiving tire there is for a race car. Would be better off with slicks from a driveline breakage aspect. As for the nitrous, you can likely spray it all you want, just don't leave on it, because you are going to break it again nitrous or not Monte
